![]() | Home > Maintenance & Mods (L322) > How to easily drop the undertray / reach into it??? |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Use a magnet and draw it to the side or nearest hole |
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
under tray is easy go remove. pull off towing eye cover, undo the 6-8 boltz holding the 2 valances. slide them off then remove the 10-12 bolts holding the undertray on. job done. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2666 ![]() ![]() |
Did exactly that , easy to get at.just undo enough to get your hand in. |
Thanks guys! It was those two bolts under the valance by the eye I had missed! All sorted now! |
