Home > Technical (L322) > Strange window behavour
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Strange thing happened today with my drivers door window. Pressed the button to the second detent to put it fully down but it only moved 10mm. Lift the button up and it moves up to fully closed. Tried it a few tomes but still the same.
Eventually I pressed the button to the FIRST detent and the window went all the way down. Pulled the button up and it went all the way back up fully closed.
Now I press down to the SECOND detent and the window goes fully down....normal operation having been resumed and it continues to work as it should.
Anyone else seen this? 4.4 TDV8 Vogue Baltic Blue MY11
Post #226749 3rd Dec 2013 7:43pm
Possibly had forgotten its calibration, had the windows on the disco go a bit dicky last week, basically had to shut them them release the switch then Hold the switch up to get them to learn the shut position.... Otherwise the auto close would not work, did the aforementioned method and all is good Thumbs Up
Dunno if it works for the ff though. There is nothing that can't be fixed with a hammer😜😜
Post #226752 3rd Dec 2013 8:06pm
