Home > Wheels & Tyres > Can I run 275/40/20 tyres on a 2003 vogue?
Plant
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Are these ok to run on a Vogue or would they cause issue with the transfer case? I have come from owning a BMW x3 where the correct tyres were essential, not sure if the FFRR is as sensitive?
Thanks in advance Thumbs Up
Post #226417 1st Dec 2013 8:03pm
because of the width you would ideally want them on 9.5j wheels , and the speedo will be out btw..
loads on here re this, have a search. ... - .- -.
Post #226512 2nd Dec 2013 1:01pm
Not ideal but yes you can and as Stan says its better if they are on the wider RRS Wheels.
Post #226513 2nd Dec 2013 1:19pm
Plant
They are mounted on a set of stormers so they are 9.5j
I take it this would be fine then?
Post #226783 3rd Dec 2013 9:31pm
i had RRS wheels and tyres on my td6 but you need to consider that the speedo will read slightly out.. ... - .- -.
Post #226784 3rd Dec 2013 9:33pm
They will run OK - just make sure you tell your insurance company
Post #226785 3rd Dec 2013 9:33pm
Plant
Will standard ffrr 255 50 20's go on them ok with the wheels being wider?
Post #226791 3rd Dec 2013 9:52pm
you can get them to fit but they wont be safe...standard 255/50/20 tyres should go onto 8.5j rims.. ... - .- -.
Post #226878 4th Dec 2013 8:26am
td6vogue
i have just bought a set of winters 275/45/20
i have read that the speedo will be out, by how much im not sure
was thinking to put the 255 on but im running the rrs stomers 9.5j so would stretch
Post #228318 11th Dec 2013 11:37am
Charlie
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Specification Revs/Mile Difference
255/50-20 671 0.0%
275/45-20 678 -1.0%
Post #228330 11th Dec 2013 12:06pm
