Home > Technical (L322) > Black smoke and ENGINE SYSTEM FAILURE messages |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35287 |
i'm not familiar with the tdv8 engine but the DPF springs to mind, try a forum search and see if the symptoms are the same.. ... - .- -.
29th Nov 2013 9:05am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Plug into diagnostics for the codes my friend...Kind of p g into the wind guessing |
Too early for a DPF Stan... 2010> ish for DPF |
29th Nov 2013 9:06am |
i'm all wet now.. ... - .- -.
29th Nov 2013 9:07am |
29th Nov 2013 9:11am |
... - .- -. Y. O. L. O. . |
29th Nov 2013 9:13am |
Ahh, it's early love |
29th Nov 2013 9:18am |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 |
Thanks folks, kind of figured that would be the case, but just asked in case it was something as simple as the silencer solution on the air suspension. I suppose I should be grateful, this pussbox actually operated properly for just on a week. First time in 6 years. 2007 TDV8 Lux |
29th Nov 2013 11:32am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
It's worth checking the air hoses from the intercooler for splits - there's also 2 x 2 inch diameter hoses that are hidden under the engine cover, 1 on the rocker cover of each bank of cylinders. They would cause the same symptoms if they are split. |
29th Nov 2013 4:09pm |
BTW, again would an OBD tool help.
29th Nov 2013 4:10pm |
Thanks cass, I will check them in the morning. 2007 TDV8 Lux |
29th Nov 2013 4:12pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Could well be the two intercooler pipes - just like the D3 one they split or delaminate and cause this. |
29th Nov 2013 4:13pm |
29th Nov 2013 4:14pm |
Thanks Martin, this is almost exactly what is happening to mine. In my case, it is fine on flat running but even the slightest hill and after a few seconds, lose of power and the message. If i accelerate up the same hill, it does not fail? Again, I will check all the pipes in the morning. Thanks again all. 2007 TDV8 Lux |
29th Nov 2013 4:31pm |
