Home > Maintenance & Mods (L322) > Part list for rocker cover gasket replacement |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
I did mine a few months back using BMW parts (listed below), dry as a bone now.
28th Nov 2013 8:07pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
thanks for your reply, very helpful. Could i just ask what the last part it. Microcat lists it as a rubber washer but only states the vehicle requires 1 but you have 6 listed?
1st Dec 2013 9:35pm |
You definitely need 6. The 16 smaller rubber seals are for the studs/nuts, the 6 larger ones are the seals for the bolts. |
1st Dec 2013 10:45pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
You don't need the 6 rubber seals as they live outside the pressure envelop but for the sake of a few £££ I would change them while you're there doing the job. You can see where the joint/gasket runs in the 2nd to last pic here. http://www.fullfatrr.com/forum/topic16756.html [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
2nd Dec 2013 10:40am |
