Home > Technical (L322) > Suspension queries |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
Once you hit 70 it drops into motorway mode!
18th Nov 2013 8:29pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Yes it drops itself ever so slightly, so little that you wouldnt notice
18th Nov 2013 8:53pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Kruger - the manual should point this out but as long as you have not "locked" the suspension mode (by pressing the button on the circular suspension select knob) then it will drop and raise.
18th Nov 2013 9:04pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
. . . . I'm sure I've read it on here before that the "motorway mode" differs for different MY's ?
18th Nov 2013 9:17pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35327 |
the 2002-2005/6 go down at around 65/70 mph and the 2006 onwards with the newer interior go down at 100 mph.. ... - .- -.
18th Nov 2013 9:26pm |
kruger2002 Member Since: 19 Jul 2013 Location: Newbury Posts: 70 |
aah... I'm not driving fast enough Currently - 55 FFRR S/C and loving it
18th Nov 2013 9:27pm |
my bad - thanks Stan..!
18th Nov 2013 9:37pm |
Me neither !
18th Nov 2013 9:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16289 |
Touchscreen cars don't have the motorway light... So, they do not lower at 65mph That's the easy way to tell which is which |
19th Nov 2013 12:49am |
my touch screen range did Craig...
19th Nov 2013 8:34am |
Wrong pic Stan, it's the square box in the middle (covered in your pic by your gear stick) that looses the motorway light on the left hand side... All the rest of the panel is the same from 02-07 but the motorway light left when the touchscreen was introduced... |
19th Nov 2013 9:21am |
i did have this 'motorway' light Craig... ... - .- -.
19th Nov 2013 9:24am |
Are you 100% sure Stan Fancy a sneaky wager? |
19th Nov 2013 9:46am |
absolutely sure Craig..
19th Nov 2013 9:49am |
