Home > Technical (L322) > damaged range rover
ruijesus
damaged range rover
Good ...
Already congratulations for the forum
I've got a big problem with my 2009 TDV8 Range and enjoyed your help.
Sometime appeared to indicate an error DPF FULL, and yesterday made ​​its regeneration with the help of the machine and everything went well .... However after making regeneration had to stop the car and he was down ... when I tried to work on the car made ​​a noise and bad at the moment when trying to work on the car so makes a TAC ....
The engine turns manually so until middle does come full circle.
During the test the engine is not warmed up, and has oil.
Before taking the test, the entire fuel system was cleaned and filters changed.
Ha any suggestions for what might have happened?
From already thank you for your help
Post #224118 20th Nov 2013 3:12pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Confused
Post #224120 20th Nov 2013 3:33pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Don't you speak French in Angola? I really do not understand your message in English.
If you send me your message in French I could try to translate it in to English
Post #224123 20th Nov 2013 4:01pm
dingg1
be better if the OP messages someone who speaks portugese
Post #224130 20th Nov 2013 4:34pm
