Home > Wheels & Tyres > Advice on pressures needed
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
I am running 255/55/20 vredestein wintrac tyres & since fitting feel that I can feel every bump in the road. I had them re balanced today which has not changed anything & am wondering if I should lower the pressues or this is a characteristic of them I need to get used to until Spring? Any advice gratefully received
Mike Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #223282 15th Nov 2013 10:32pm
Googsy
What pressures are you running?
33 36 is normal but less if your in car on your own mostly 31 34.
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #223286 15th Nov 2013 10:58pm
AJS4X4
Think you will have 255/50x20 on your car. Thumbs Up
You can run standard pressures but we find +4psi above standard un-loaded pressure works for most. Thumbs Up Andy....
www.ajstyres.co.uk www.ajs4x4.co.uk
01737 241370.
Always best to phone first.
Post #223288 15th Nov 2013 11:05pm
Thanks Googsy am running 36 rear & 32 front when cold will lower them a bit in the morning. I have ruled out anything else as on totally smooth tarmac its lovely. However when the wife says her 407 is a smoother ride on most the roads around here it hurts your feelings Sad Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #223289 15th Nov 2013 11:06pm
Thanks to Andy, just braced the cold to nip out to the garage & they are 50 Thumbs Up so what exact pressure would you recommend? Will also need some summer tyres in spring maybe you could pm me a quote inc delivery for a set of pirrelis? Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #223291 15th Nov 2013 11:10pm
AJS4X4
Give them a try at 36F and 40R, as I said this works well for most. Thumbs Up
Do not forget...........to low a pressure will cost you more in fuel and will cause the outside shoulders to wear.
Also running to high a pressure will cause the centre of the tyre to wear more than the rest of the tyre but will give better fuel economy, the pressure I recommend is about where it is best for the Wintrac. Thumbs Up
Tyre pressures are a recommendation which you can adjust to suite your requirements and what works best for you.
50psi is way to high IMHO but I don't think you should drop below 32F and 36R.
Hope this helps. Andy....
01737 241370.
Post #223313 16th Nov 2013 7:53am
I have wintracs on and they're very comfy - but mine are on 18's.
How'd you end up at 50psi?
Post #223316 16th Nov 2013 8:33am
put 33 front and 36 rear to start with and adjust up or down for comfort.. ... - .- -.
Post #223335 16th Nov 2013 10:19am
Thanks everyone Thumbs Up Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #223342 16th Nov 2013 12:42pm
Discotigger
I think he was talking about the tyre size!! Mike had originally said his tyres were 255/55/20, AJS had said they must be 255/50/20.
Think Mike was just confirming they were 50's Thumbs Up
Post #223367 16th Nov 2013 3:26pm
Now im confused lol, To confirm I was verifying the tyre size as I had mistakenly put 55 Thumbs Up Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #223371 16th Nov 2013 4:32pm
