Home > Technical (L322) > Smoke form Pre Heater?
andrewcooke1720
Ireland 2012 Range Rover Westminster 4.4 V8 Barolo Black
Had a look around the forum but still not sure whats going on, 07 TDV8 Vogue, large amount of smoke coming from the passenger side 2 to 3 minutes after start up and really noticeable when stopping at lights, junctions. Guess its the Pre-Heater but whats causing the smoke? un-burt fuel?
Is this a "bend over main dealer fix" Bow down or can I buy a replacement "something or other and fit it myself"? Thumbs Up
Thanks
Post #220972 5th Nov 2013 6:55pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Normal operation , not a problem
you can also run some diesel cleaner for a couple of tanks to clean the injectors out and the injector nozel on the webasto heater Far to many gone...
Post #220974 5th Nov 2013 7:01pm
As above, normal at this time of year. It has been sitting idle all year and will need a few cycles to clean itself out.
The first time my one started I thought the FFRR was on fire ! Laughing Previously..
Post #220983 5th Nov 2013 7:56pm
a better way to purge it is to used the timed climate for 20mins before you want to use the car to fully get the unit up to temp and burn the deposits off Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #221134 6th Nov 2013 12:55pm
when they replaced mine last year the smoke/fumes it gave out (new one) was extraordinary!
normal operation for it to give a bit of smoke, general rule of thumb, if there is warm air coming out of the vents its working fine Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #221218 6th Nov 2013 5:47pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
there is nothing more satisfying than getting into a warm car at this time of year when it is damp and cold on a morning, I use my heater all the time. the remote control is the best thing, sat in the house with a warm coffee, press the button and bobs yer uncle, on she goes, blowing smelly diesel fumes all over next doors car while they are trying to scrape the ice off the windows... Laughing Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #221874 9th Nov 2013 4:42pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Yep Smile
Post #221886 9th Nov 2013 6:03pm
