Home > Technical (L322) > Changing rear parking sensor loom L322
vogue12345
Hi guys
Had some advice from some of the members a while ago about the rear parking sensors.
I took the bumper off the back to change the loom but found there was a small round hole where the wire lead to and could not get to the source of where the loom was plugged in.
All 4 rear sensors are clicking but still getting a flat line sound when reverse gear engages so the loom is what the lads said is most likely the problem.
If anyone can advise instructions or advice on how to change the loom on the rear it would be much appreciated
Thanks!
Post #218655 25th Oct 2013 12:13pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
it may be a fault in your front sensors if all 4 rears are clicking ok?
Post #218683 25th Oct 2013 1:56pm
vogue12345
Hi mate
Sorry should have mentioned - all 4 front sensors are clicking work fine and the PDC on the front is ok it's just the back
Thanks
Post #218699 25th Oct 2013 3:28pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
The plug should be easily accessible when you slide the bumper back. It's on the right hand side and is way too big to fit through the hole into the body. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #218795 26th Oct 2013 6:04am
When you select reverse, what is the light on the switch doing? Is it flashing or does the light remain on?
Post #218804 26th Oct 2013 7:40am
vogue12345
Hi guys
Thanks for the replies
When I took the bumper off, I followed the loom up to the point where there was a small hole and I just couldn't get access to get the old one out and couldn't see where it finished (i.e. where that scart like end is on the loom)
Regarding when reverse is selected - it's a solid orange (doesn't flash) and a solid tone sound
Thanks
Post #218814 26th Oct 2013 8:08am
vogue12345
Anyone have any thoughts on this?
Post #219202 27th Oct 2013 10:21pm
