Home > Technical (L322) > IId tool
Page 3 of 3 <123
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
Ok it's like Xmas come early
This arrived Friday from Canada Thumbs Up
Just need to get some time to play
Can't wait to play
Might come home early tomorrow :whistle:
Post #220536 3rd Nov 2013 8:06pm
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
These any use ?
http://www.machinemart.co.uk/shop/product/...TC=SRC-obd
Post #220549 3rd Nov 2013 9:12pm
the only problem with these readers is that they only clear generic codes/faults....
vehicle specific tools like the iidtool,faultmate etc can clear all the codes.. ... - .- -.
Post #220550 3rd Nov 2013 9:14pm
It's about time I bought one of these.
Where's the best place to source one from ?
Post #227602 7th Dec 2013 11:40pm
island 4x4 seem to be competitive or try ebay.. ... - .- -.
Post #227777 9th Dec 2013 11:36am
SteveMFr
Site Sponsor
Glynn wrote:
These any use ?
Hi Glynn,
I posted a while back on choosing a diagnostic system and what the differences are - see below. Some generic OBD readers work poorly or not at all and even more will not clear codes, but they all only work on emissions related components (=drive train).
If this is all you need, then simply make sure machine mart will take the tool back if it does not work on your RR.
SteveMFr wrote:
Choosing a diagnostic system is not always easy. I posted some background info in a thread similar to this on another forum a while back. I tried to keep it objective - if you want complete objectivity do not read the '*explanation...' at the end of the post Razz
HTH in deciding what is best for you.
There does not seem to be much clarity on the functions of a diagnostic system and what to expect when you use one. Here's a short explanation (EDIT: ok long...)
First, there are several basic types of functions that a diagnostic system can have:
- fault code reading and clearing
- live values and component manipulation (to check operation) or executing service routines (such as for the EPB)
- Editing the car's configuration files (CCF)
- Initializing, calibrating, or programing new components
- Flashing SW to the ECUs (as for updates)
Then you have to separate different types of faults or DTCs (Diagnostic trouble codes):
- generic OBD codes: these are all the emissions related codes that come from the drivetrain (motor and transmission). These are standardized across all manufacturers so that they can be read all over the world at emissions testing stations. There are OBD readers starting at £25 that do a fine job of reading these. Some even manage to clear fault codes.
- manufacturer specific codes: all the rest of the systems on the vehicle. In a Hyundai that is probably not too much, but in a modern LR it is quite a bit - and many items such as the EAS, ABS, DSC, etc. are vital for vehicle operation as well. These can only be read by manufacturer specific code readers.
You can also separate the diagnostic systems into different categories:
- generic code readers: only emissions related OBD codes. Start at ~£25. Some of the more expensive ones may include live values (engine/trans only) and the non-generic ability to clear SRS faults (turn off airbag light) which makes them attractive for small, independent repair facilities.
- manufacturer specific fault code readers: can only read and clear faults. Shows no live values, allows no manual component activation/testing, no vehicle programming, etc. The only 'pure' fault code read/clear device for LR vehicles is the Blackbox FCR.
- manufacturer specific diagnostic systems more for personal than professional use: allow some or all of the functions of a full diagnostic system: live values, manual component activation/testing, vehicle programming, etc. Depending on the cost, these may or may not be locked to one vehicle VIN and have increasingly more functionality with increasing price (we went a slightly different direction to try to reverse this trend for the IIDTool - see below*). These start at the low end with the RoverAllComms (only early RR L322) and Hawkeye, and go through our IIDTool and the Blackbox Faultmate. The latter 2 are VIN locked.
- professional diagnostic systems: these include the OEM LR IDS/SDD, Autologic, Blackbox Faultmate, and IIDTool Pro (coming end of 1st quarter 2013)
Choosing the right system requires spending a bit of time looking at all of the relevant information. If you do not want to do any CCF editing and a a fair bit of basic maintenance on several LR's, the BBS FCR or Hawkeye might be the way to go (but be aware that the functions offered are quite basic - for instance the Hawkey can not do an EAS calibration if you replace a height sensor). If you want to do more but only on a few vehicles (say 1-3), you'll have to look into what the BBS Faultmate or IIDTool have to offer. If you have a club (or for an independent service facility) you can look into one of the professional systems.
*Explanation on the IIDTool pricing: We specifically looked to partner with a large retailer in order to be able to sell larger volumes and keep the price very competitive. In our case this worked out well with Britpart as our distribution partner. We also used the vehicle as an 'interface' to keep hardware costs low (thus Integrated Interface Diagnostic Tool). Essentially, the IIDTool provides similar functionality to diagnostic systems costing 3-4x as much.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #227806 9th Dec 2013 3:50pm
Thumbs Up On the Christmas list
Post #227837 9th Dec 2013 8:58pm
Page 3 of 3 <123
