Home > Wheels & Tyres > Axle Stands
Rambles
Axle Stands
which ones are recommended?
Post #217337 18th Oct 2013 9:07am
anything from 2 tonnes upwards .. ... - .- -.
Post #217364 18th Oct 2013 12:31pm
Martin
Site Admin
Buy the best you can afford, they are the only things stopping a vehicle squashing you flat.
Post #217371 18th Oct 2013 12:51pm
Rambles
most have minimum / maximum heights
i am guessing 430mm maximum is not going to be enough? do I need more like a range from 400mm to 600mm?
Post #217385 18th Oct 2013 2:20pm
these are the ones i use..
http://www.machinemart.co.uk/shop/product/...xle+stands
max height is 430mm and thats enough.remember its not the body that is 'suspended' but the chassis... ... - .- -.
Post #217393 18th Oct 2013 2:49pm
TugRR
^ Me too - good heavy duty product
They also do a taller/broader one -
Thumbs Up Where do you go after one of these . . . ?
Post #217416 18th Oct 2013 4:51pm
Stan, I don't understand. It's a monocoque?
Post #217419 18th Oct 2013 5:05pm
i meant the metal bits underneath.. Wink ... - .- -.
Post #217432 18th Oct 2013 6:01pm
Ah.
Post #217434 18th Oct 2013 6:11pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Going to pick up a set of 6 tonne ones with plenty height adjustment tomorrow.
Post #217718 20th Oct 2013 3:31pm
