Home > Maintenance & Mods (L322) > Rear differential on 4.2 SC
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
My 4.2 SC rear diff now as leaks on all three couplings. The leaks on the drive shaft couplings are negligible, more like weeps, but the prop shaft coupling leak is more recent and substantial.
I will be looking at repairs but at this age (156k), I am also considering replacement if I can find a reputable service exchange or refurbished diff option. Whilst repair is likely to be cheaper in the short term, there my be a longer term case for replacement, especially if I can get a good deal on fitment.
I would be interested to hear the experience of others and any recommended suppliers. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #208990 9th Sep 2013 5:54am
If it is simply the seals which have gone then it will be a lot cheaper to fix it, so long as the internals are ok then there is no reason it wont last another 150k before going again. There is nothing that can't be fixed with a hammer😜😜
Post #208991 9th Sep 2013 6:30am
Most important is to check for water ingress... Check the oil condition first and if no water then i agree with above Thumbs Up
Lots of leaks happen because water gets in, rusts the shafts which Censored the seals Rolling Eyes etc etc etc
Land Rover replacement is £1600-£1900
Transmission companies usually cost £800-£1000 to refurb them Thumbs Up
Post #209025 9th Sep 2013 10:25am
RRBlue
Thank you. Great advice from both of you.
Dealer has quoted same numbers.
I will be getting the seals replaced! 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #209083 9th Sep 2013 5:15pm
RRBlue
Took the RR to a local independent land rover specialist at Wicken near Ely to sort out leaking seals. When they were able to inspect the diff properly, rather than waving a torch whilst lying upside down on the drive under the car, they found that the breather was blocked and that oil was trickling down over the three couplings.
They unblocked the breather, cleaned the diff and test drove to see if the problem was solved. All for £50.
Big relief. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #213314 1st Oct 2013 5:56am
pld118
Good for you. Great result Thumbs Up
Post #213318 1st Oct 2013 6:16am
Might be worth getting the diff oil changed as a precausion anyhow Thumbs Up
But, great news Thumbs Up Thumbs Up Thumbs Up big relief i would imagine Wink
Post #213329 1st Oct 2013 7:38am
Great news!
Seconded on the diff oil change. Thumbs Up Si. <This is my name.
Post #213352 1st Oct 2013 9:18am
RRBlue
Indeed, have bought the oil already. Only changed it a few months ago but was planning another change as there was so much debris on the magnetic drain plug that I wanted to see if this was still accumulating.
The latest leakage epidote reinforces the need for change as I am not sure how much has been lost through the breather. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #213383 1st Oct 2013 12:24pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Great news. Nice to hear of a cheaper than expected repair!!
Post #213396 1st Oct 2013 1:06pm
RRBlue
I finally got round to replacing the diff oil after the breather blockage. Attached are pics of the diff drain plug magnet. Large gritty metallic deposits. I only changed the oil 6 months ago at which time the drain plug had a 10-15mm thick dense deposit attached go it. I thought it would be clean this time. Also in six months the oil has gone from a fresh urine appearance to black.
Anyway, fingers crossed that all is well. I gave the outside of the diff a good clean with Gunk so that I can monitor for any new leaks. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #219330 28th Oct 2013 3:45pm
