Home > Maintenance & Mods (L322) > 2007 side lights
daveo
2007 side lights
hi just a quick one, my mate has just dropped of wat are ment to be the dogs nuts in led side lights that will match the headlights 100%, no errors, not to bright..
do you get to the side lights from under the bonnet or from the wheel arch. V8 facelift Range Rover Autobiography 22" wheels.
Post #17730 1st May 2010 7:37pm
Rave manual says the following:
Disconnect Battery Earth
Remove thumbscrew securing lamp assembly to headlamp mounting bracket
Slide lamp assembly forward, disconnect multiplugs and remove lamp
I'm guessing you access from inside the bonnet although I've not tried and it's dark, there's a bottle of red going down nicely and the log fire is crackling away. Very Happy Discovery 4 HSE
Post #17731 1st May 2010 8:09pm
daveo
thanks, he has given me led for the inertia that dim correctly, my brothers 09 bmw has all led lights on the inertia ands as long as you don't over do it, brightness wise it looks well
will investigate tomorrow V8 facelift Range Rover Autobiography 22" wheels.
Post #17732 1st May 2010 8:22pm
You've lost me. LED for the inertia? What does that mean?
(I have a horrid feeling I am about to be exposed as really thick now... Big Cry ) Discovery 4 HSE
Post #17733 1st May 2010 8:43pm
DMRR
I am going to assume....possibly wrongly he meant interior..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #17734 1st May 2010 8:48pm
daveo
that's what you get for typing in the dark..i meant interior V8 facelift Range Rover Autobiography 22" wheels.
Post #17735 1st May 2010 10:18pm
daveo
hi, what ever way i look at it. it appears like the headlight must come out to change the side lighs, its had the 2006 headlight conversion and the access cap is positioned right in front of the inner wing, i can turn it and remove it but cant get my hand in there, V8 facelift Range Rover Autobiography 22" wheels.
Post #17762 3rd May 2010 6:59pm
