Home > Wheels & Tyres > TPMS HELP! |
Get your self a GAP products IID tool and turn it off your self in the CCF files
25th Sep 2013 5:54am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
i have the same problem with intermittent 'check all pressures' warning...my vales look corroded and the batterys in the tpms are probably going flat causing the random errors..
25th Sep 2013 7:41am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Thanks. The mechanic has a computer tool (not sure if it's the IID), and the dealer certainly does. So...
25th Sep 2013 8:01am |
here's the link to the GAP site,
25th Sep 2013 8:11am |
The CCF is the Car Configuration File and it tells the various ECUs which options the car has fitted. The CCF can be accessed with a number of tools, such as IID and Faultmate to pick just 2.
25th Sep 2013 8:14am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
I asked the Main Dealer why not just remove the corroded TPMS valves and replace them with standard rubber valves and was told they would/could not do this as TPMS was manufacturer spec and to do that represented a potential safety issue. So they replaced all the TPMS. Maybe Main Dealers won't do it for fear of being pursued if there are any resultant 'issues' that they feel could 'come back and bite them'? |
25th Sep 2013 9:00am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Potential safety issue is utter rubbish as not all vehicles had TMPS fitted!!
25th Sep 2013 9:45am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6738 |
I've used the IIDTool to turn off TPMS on both cars I've had.
25th Sep 2013 10:03am |
Not disagreeing with you Graemec, just recounting what I was told ...
25th Sep 2013 12:51pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
IID Tool is your friend............I turned mine off Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
25th Sep 2013 3:48pm |
It sounds like I'm one of the very few that has had no problems with the TMPS (yet ??) and only had it do what it is designed to do, warn me one of the tyres is underinflated. I have had three flats and all three were detected by the TPMS before I drove of (and would have done more damage, potentially).
25th Sep 2013 4:15pm |
Thanks to all for the replies.
25th Sep 2013 10:28pm |
