Home > Technical (L322) > Starter difficulties
RangerBergen
Norway 2003 Range Rover Vogue Td6 Buckingham Blue
My 2003 RR 3.0TD6 has problems starting. After a few turns from the starter, the motion ends and I just hear a buzzing, slurring noise. After a couple of tries it usually somes round, but this is extremely irritating!
It has 145k km on the clock, and I have changed the front diff, ref earlier posts. Anyone?
Post #1103 21st Oct 2008 2:32pm
Are you sure your battery is still up to the task?
That whirring buzzing noise sounds like the noise made when there's not enough battery power to crank the engine and just the starter spins round.
Or, perhaps the starter is on the way out?
Get the battery checked by someone with the right kit to see how much residual power it has in it. I would guess that's your problem. Discovery 4 HSE
Post #1105 21st Oct 2008 2:35pm
RangerBergen
Yeah, I thought of the battery, but that usually makes the starter turn slower/less every time I turn the key.
In this case the starter turns better after a while, and it typically takes approx five minutes and then it suddenly catches and starts great. Have had some noise from the starter earlier, especially when the engine is cold. This came on over night, and I guess it has to be the starter. The garage supplied me with a new one, installing Friday. Will keep you updated.
Post #1106 22nd Oct 2008 6:43am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
How have you got on Chap?
Post #1155 28th Oct 2008 6:19pm
RangerBergen
Well, still not finished at the garage. They had to change some bushings as well. And the they had to replace the steering column, because some Censored at the garage in Spain had pulled its clamps through the holders inside the dashboard. So the steering wheel was loose. I thought it was just the electric adjusting that was off, but no. Loose steering wheel...
Also a lot of hassel recently with the electronics, can't select Sportmode and the display shows "trans. failure prog." They ssaid this wasfixed.
My car will be done tomorrow or friday. Will keep you posted.
Post #1165 29th Oct 2008 10:33am
ken
Good luck Thumbs Up
Post #1166 29th Oct 2008 12:15pm
shmoogle
United Kingdom 2008 Range Rover Autobiography Supercharged Chawton White
Shocked Halfway Down The Stairs,
Is the Stair Where I Sit.
Post #1194 31st Oct 2008 3:22pm
RangerBergen
Still not finished. Maybe monday/tuesday the say. The local dealer is unbelievably crap so some guys at OEC has it. They all drive LR's so the must be good for something. The figured out the transmission problem was caused by the gearshift motor, due for changing. This is gonna cost. Latest figure about 3000 pounds total.
Post #1205 1st Nov 2008 2:07pm
Sorry to say but i wouldn't throw 3k to a car that needs repaired, Would just go out and get another one with it being on a 03 plate.
2003 BLUE LAND ROVER RANGE ROVER VOGUE TD6 (2003)
81,300 miles, This Range Rover is top of it class, it has a full Vogue spec plus extra. this is in emaculate condition in side and out (like new) Show room condition ...
Full Details
Surrey
£3,700
Advert seen on pistonheads either the guy is skint or there is a 1 missing.
Post #1206 1st Nov 2008 3:37pm
What? £3,701 ?
Rolling with laughter Rolling with laughter Discovery 4 HSE
Post #1209 3rd Nov 2008 9:26am
RangerBergen
Well, with the prices in Norway, especially for cars like these you would have opted for repair also.
I bought my Vogue november last year, for 62.000 £. 03 plates, TDV6, 124000km.
It was a bargain. This car costs approx 148.000£ in Norway
Post #1291 15th Nov 2008 7:34am
Sorry, did not know they were that price Shocked , would it not have been cheaper to get one from the uk and drive it over. i can understand now why you would pay that for repair.
Post #1292 15th Nov 2008 10:10am
RangerBergen
That would have been cheaper, but to register a car in Norway you have to put a norwegian license plate on it, and of course pay the taxes on it, so the amount saved would be marginal and not worth the hassle.
And of course, the steering wheel in your cars are on the other side.
Post #1294 15th Nov 2008 10:40am
Yeah but thats your fault for driving on the wrong side of the road Rolling with laughter Thumbs Up there are plenty of left handers for sale over here
Post #1295 15th Nov 2008 11:01am
RangerBergen
Must check them out then. But the tax is a bitch, especially in Norway...
Post #1296 15th Nov 2008 11:45am
