Home > Maintenance & Mods (L322) > Knocking on near side front
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Had a slight knocking on the near side front.
Lower suspension bush was worn and lower ball joint moves very easy.
Ordered new bush and ball joint just changed them out today so will give it a spin later and see if its sorted.
If its ok will book it in for 4 wheel alignment check and get the steering wheel back to the centre as its just off at the moment. Its was like this when i bought the car.
Then we will see if the steering is better
Post #210726 17th Sep 2013 1:35pm
ok. Thumbs Up ... - .- -.
Post #210727 17th Sep 2013 1:51pm
steve9bug
Car is great no knocking now and a better drive so will get the four wheel tracking looked at now Cool
Post #210792 17th Sep 2013 8:40pm
excellant. Thumbs Up ... - .- -.
Post #210826 18th Sep 2013 7:42am
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Mine has similar symptoms
Hopefully that's all mine is
Post #211167 19th Sep 2013 7:41pm
SATVC
How much was the parts?
Post #211168 19th Sep 2013 7:41pm
steve9bug
Bush was just over £40 and ball joint £15
Post #211172 19th Sep 2013 8:02pm
GraemeC
Good job Steve - mine had a similar knocking and a near side ball joint sorted it
Very wise to get the tracking done - mine was all over the place and felt much better once corrected 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #211177 19th Sep 2013 8:26pm
steve9bug
I need to when i bought the car they did th O/S ball joint and arm so now they all are ok it needs it will steer better and also get better tyre life
Post #211236 20th Sep 2013 8:50am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
how easy job is this to do?
Post #211265 20th Sep 2013 10:30am
steve9bug
Not hard but need a bit heat on arm to get bush out if you use a vice like me but a press would make the job easier.
You can get the bus in a new arm ready to fit for a little bit more and its just a bolt and ball joint nut change the ball joint is only in with 2 torques bolts.
Post #211282 20th Sep 2013 11:52am
GGX
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
How long do they last? Replaced front arms last year / 18k miles ago and got knocking again?
Crying or Very sad
Post #211858 23rd Sep 2013 9:43pm
steve9bug
did you do the ball joints
Post #211920 24th Sep 2013 8:12am
Crying or Very sad
Did you fit genuine LR parts from Land Rover or were they 'OE' from another source?
Post #211926 24th Sep 2013 8:16am
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
had the same prob on mine replaced the ball joints ,replaced the upper bushes ,still knocking,i finally found it to be the nearside track rod end ,did that tracked it up perfect,different car to drive now.
Post #212181 25th Sep 2013 9:04am
