Home > Technical (L322) > AGM v lead / acid 110AH |
I thought about fitting an AMG batterie but like you I questioned the ability of my( older model) alternator to recognise the higher demand of the AMG so I went my own way and put in a 110 Ah Leisure batterie , my thinking being it would have the deep capacity to run my FBH without trouble and being a petrol V8 it seamed not so important to have quite as much cold cranking as a desisel . 2008 MY Supercharged
17th Sep 2013 4:50am |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
Hum, i had an AGM battery fitted about 2 years ago - garage didn't 'change' anything it was a straight replacement.
17th Sep 2013 6:28am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I put an AGM battery in my last car and had it around a year (through two winters) without any problems or dealer mods?
17th Sep 2013 11:41am |
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 |
Dealer replaced my dead battery with new one under warranty on my 2012 TDV8. Honestly previously did not check what I had there, but he later claimed that it was an ordinary flood type and not AGM. Altough now they gave me an AGM type, but only 90 Ah. When I was asking for 110Ah, he told that 90 is the official on this 2012 4,4 TDV8. Moreover I don`t think he would be doing any reprogramming, update etc...
18th Sep 2013 5:44am |
Standard fit IIRC has always been 90ah Really should be 110ah but this is a tight fit so an extra 60seconds on the production line to shoe horn in.
19th Sep 2013 10:11am |
Just checked my battery and its an Exide 90 AH AGM with a Jaguar Land Rover logo so assume its from new?
19th Sep 2013 7:15pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
A leisure battery, regardless of the capacity is not as great idea. Leisure batteries are not designed for a high output (like working a starter motor) but for a steady output and deep discharge. The opposite of a car battery. It might be OK for a while, but it won't last as long as a proper battery. Some useful tips here: http://www.aandncaravanservices.co.uk/battery-technology.php |
19th Sep 2013 7:36pm |
Thats strange as i thought they never fitted a 110ah Lead/Acid battery at all and that the standard 90ah one fitted was replaced with the AGM model to resolve Park Heat issues and then the timer reduced as well to help it live longer but also to factor in the short runs a lot of customers were doing allowing the AGM to get back upto full again quite quickly. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
19th Sep 2013 11:09pm |
Simes I have previously read that but I am using a battery we use in the marine world that I have a lot of experience with where the plates are not that thick and have found that it copes with the much more complex requirement of a boat i.e., starting duties, deep cycle duties like running a heater and good steady voltage like running the navionics .
20th Sep 2013 3:18am |
I think the leisure battery is a good call with your petrol engine.
20th Sep 2013 6:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
leisure battery's shouldn't be used in a car due to its different construction,it might be worth having a read here where it explains it better,
20th Sep 2013 7:47am |
At the risk of dragging things further off course a lead acid battery is a lead acid battery just different thickness and number of plates , a "starter " just has thin plates to give the biggest bang for your buck but sulfurate badly if you abuse them most "leisure " batteries have moderate plates thy are just a bit big and do just fine as a starter as well and some batteries have muckle thick plates and just can't dump the amps to cut it as a stater .
20th Sep 2013 9:09am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 800 |
seems to me that if I fit a lead acid battery to a system set up for an AGM
21st Sep 2013 9:35am |
Over charging is often used by a lot of battery chargers anyway. CTEK's do this as it helps get rid of the sulphation and bring back dying batteries FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
21st Sep 2013 10:20am |
