Home > Technical (L322) > Unplugged things in the engine bay?!
TommyZoom
2003 Range Rover Vogue SE Td6 Zambezi Silver
Hi all, bit of an odd one, (I think?!) I've had my TD6 FFRR for about 4 months now. It asked for coolant so I filled it up and checked the other bits in engine bay. I came to notice that there are a couple of wiring loom type things, which split into 2 at the end. 1 is plugged in and the other is just a plug, that looks like it could be plugged into the bit where the other plug is! Anyone have any idea?! Current: 2003 Range Rover Vogue SE Auto TD6, 2004 Mercedes C270 CDi Saloon Elegance SE
Gone: 1966 Land Rover Series 2a, 1999 Mercedes A170, 1998 Vauxhall Omega Estate 2.5 V6
Post #210134 13th Sep 2013 9:04pm
There are loads of 'spare plugs' on the TD6 that are not connected to anything. The loom is probably generic to fit various models and comes with all the fittings
Post #210136 13th Sep 2013 9:20pm
mjdronfield
Perhaps for the electric fan that fits in line with the fuel cooler. This was only fitted to Td6's in very hot climates, so not Europe then !!
There are a few unused ones on mine too. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #210186 14th Sep 2013 9:35am
