Home > General > To SC or not to SC.........
Steve , remember that Eugene lives in a country with extreme temperatures and humidity and his s/c has to suffer those conditions.. ... - .- -.
Post #212657 27th Sep 2013 10:14am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
@Stan - Good point! We've had a goodish summer but not quite as hot as Lagos!!
@Ryan - Brilliant write up. Scary! But very informative and well written. Thank you (on behalf of many I'm sure) this stuff is invaluable. Yes, I have a FF TD6 so well aware of the little moments they can have, this is a hard decision because the TD6 is running as sweet as ever. Funnily enough, the current SC owner previously had a TD6 too (he jumped ship after having to shell out for a gearbox!) and he says that apart from the EAS pump it's been faultless.
A hard call! Thanks again for the input. I will keep you posted. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #212659 27th Sep 2013 10:27am
markdotreed
You won't regret moving to an SC. They defy the laws of physics. Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #212661 27th Sep 2013 10:37am
ebajema
My SC was imported from the US (Texas by the looks of things) and has been sitting outside for 2 years without moving (all the paperwork matches up with the mileage it came with 48,000). It most likely killed my AC seals so that has been replaced about 1 1/2 year ago.
I am actually surprised that there aren't any more heat/moisture related problems to be honest. It could have been a lot worse.
The fuel system issues I have had are very likely caused by sitting still and having really crappy petrol in it. I was lucky that a brand new fuel pump set showed up on EBay. It drove fine just not as well as it should, now it is perfect.
The gearbox issue is just bad luck and the coolers is a Censored -up by the mechanics and it took me too long to find out (a full year after they had put the water in, when the AC was done).
I would not hesitate to buy another SC, I would get one in a heartbeat, preferably a 5.0 if I could afford it. I would also still buy this model again since I now know the weak points (rear calipers and those two cooler/heat exchangers).
I still, despite the issues, don't regret getting this particular FFRR, it puts a smile on my face every single time I get in and I hope I will be able to keep it for many many years to come.
As for the coolers DEFINITELY change them for new ones is my opinion. They are not expensive (about 140 Euro each I believe) and putting them in is not easy (tight spot) but the boys did it quite quickly (the hoses are quick connect).
If they go then the cost is much much higher. First you need to flush the cooling system to get the oil/coolant mix out and that takes FOREVER. Worse is the gearbox, you have to change the ATF at least 5 or 6 times and that is VERY expensive if you use the ZF oil and expensive if you use another top quality ATF (I used the top spec Toyota ATF). Filter on mine is going to be replaced next and then the ZF ATF goes in.
The engine oil one, went a month later and again the cooling system needs to be flushed FOREVER, I still had crap coming out this week. I was lucky though, the oil seems clean (although during my Dec leave I will have it changed). MY 2010 5.0 SC Galway green and sand interior!!
Post #212663 27th Sep 2013 10:56am
SKOT
Collected this morning, so it looks as though it's "to SC"......... 2006 4.2 SC
Post #213100 29th Sep 2013 9:54pm
ebajema
Congratulations !!! Look forward to the pics Wink MY 2010 5.0 SC Galway green and sand interior!!
Post #213132 30th Sep 2013 9:39am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Welcome to the club Thumbs Up
I've had mine over 4 years and apart from some wobbles (usually a minor issue on top of me having a bad week!) I still feel happy to own it and it's just sailed though another MOT with no advisories.
Very Happy
Steve
Post #213137 30th Sep 2013 10:24am
!!Welcome Smile i have mine for 3.5 years now and the car still runs perfectly Smile All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #213193 30th Sep 2013 2:26pm
