Home > Technical (L322) > Help needed to switch off TPMS
Just had my wee sister on the phone. Her TDV8 Vogue is throwing up TPMS errors. The valve stems are corroded I believe.
Is there anyone near LANGLEY that could switch the error off for her?
Cheers.
Archie. Previously..
Post #208342 5th Sep 2013 6:50pm
Anyone in Berkshire ? Previously..
Post #208409 6th Sep 2013 8:47am
from another thread,
daveo in london
simple1 near longleat ... - .- -.
Post #208412 6th Sep 2013 8:50am
steves025uk
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
I asked Guy Salmon, Thames Ditton, Surrey, to turn it off when it was serviced, they said it couldn't be done ? but, it would not fail the MOT due to the 'intermittent warning light/message.
Post #208751 7th Sep 2013 7:45pm
IIDTool can switch it off.
There's no way an MOT inspector can tell it's been disabled, but my local dealer said they wouldn't disable what they considered to be an essential safety feature. Load of BS, since not all models have it! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #208752 7th Sep 2013 7:47pm
ebajema
Faultmate users can switch it off. MY 2010 5.0 SC Galway green and sand interior!!
Post #208753 7th Sep 2013 7:48pm
^ I believe so... Just the ccf needing edited. Previously..
Post #208757 7th Sep 2013 7:59pm
A word of caution, if the car was first used on or after 1 Jan 2012 the TPMS system if fitted is testable as part of an MOT. ie the warning light has to operate correctly and not show a fault.
Post #208759 7th Sep 2013 8:12pm
I don't see how that can be tested by an MOT tester, since, once it's been disabled, there are no indications of any kind. Even when it is enabled, I don't recall there being an indication when the car's switched on, but I could be wrong. Got - 2017 SDV8 Autobiography in Loire Blue
Post #208762 7th Sep 2013 8:50pm
Bigmick
I was told last week by an MOT tester that VOSA have changed their minds again and TPMS warning light was now just an advisory (again) Mike
Gone:-
2004 V8 Autobiography
1998 2.5 DSE
1993 200Tdi Classic
Post #208763 7th Sep 2013 9:00pm
Clear as mud then! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #208764 7th Sep 2013 9:06pm
It's still listed in the MOT Inspection Manual as a testable item.
Post #208765 7th Sep 2013 9:16pm
Paul J.
If the valve stems are corroded, change them ASAP. Corroded valve stems will not be causing the error, but they could snap off with minimal effort (e.g. checking the tyre pressure as they did on mine). If the valve stems are corroded, it may be worthwhile raising this with your local dealer - mine were replaced no questions asked, even though the car was out of warranty.
I recently had an intermittent problem with my TPMS. Eventually I opted for a new control module, which fixed the problem. ISTR it was about £200 fitted.
Post #208960 8th Sep 2013 10:10pm
They are getting them replaced, but not with TPMS valves. It's a late 2007 tdv8.
Was hoping someone could help switch off the warning. Previously..
Post #208962 8th Sep 2013 10:18pm
Funny how threads go off-topic! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #208977 8th Sep 2013 11:12pm
