Home > Wheels & Tyres > New tyres-Should i replace the TPMS?
T24RES
Just bought new tyres for the FF. The TPMS works fine at the minute.
Should i be thinking of fitting new TPMS or wait till they die?
Post #208331 5th Sep 2013 5:03pm
How old are they? If original, replace... Batteries only last so long. Previously..
Post #208334 5th Sep 2013 5:12pm
supershuttle
My newer wheels have TPMS valves but the car doesn't have TMPS do I leave 'em alone or get them taken off and replaced with std ones? Geoff
Post #208351 5th Sep 2013 6:29pm
T24RES
The current TPMS are coming up to six years old. How long do the batteries last, any idea?
Is this what i need...... http://www.ebay.co.uk/itm/JAGUAR-TPMS-Valv...422wt_1060
Post #208391 6th Sep 2013 6:19am
GraemeC
T24res - they look exactly what you need. You might be able to get them a bit cheaper, there were a coupe of sellers doing sets of 4 for £30-40 a while back
Super shuttle - if you car doesn't have TPMS better to replace with normal valves. As the TPMS valves age the alloy can deteriorate - some people have snapped the valves when filling their tyres with air!
Easier and safer just to use a normal valve, however you've probably got 5-6 years before it becomes an issue!! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #208394 6th Sep 2013 6:40am
GraemeC
Batteries are supposed to last anything from 5-7+ years but it depends on where you drive as the monitoring frequency changes (IIRC lots of motorway will result in fewer 'connections' resulting in a longer battery life) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #208396 6th Sep 2013 6:46am
ebajema
My car was built in 2005 (May) and the TPMS is still going. Mind you, the car has been sitting still for 2 years after it was imported from the US into Nigeria and only had 48,000 miles on it. I added about 10,000 since. So they are well past 8 years and I'm kicking myself that I didn't get that whole batch of TPMS valves (both UK and US frequencies) as I would have been able to sell you a set quite cheaply (while keeping a set for myself spare).
Looking at the potential lifetime of tyres, depending on how many miles you do per year, it is to be expected that yours would run out of battery before the next tyre change.
I assume that you don't have any TPMS issues (neither do I, they work very well) like a lot of people on here that have subsequently switched them off. MY 2010 5.0 SC Galway green and sand interior!!
Post #208399 6th Sep 2013 7:09am
T24RES
OK, looks like i'll get a set off of the bay. I've had no issues so far and will keep with them.
Post #208884 8th Sep 2013 3:23pm
T24RES
£48 posted, that'll have to do.
Post #209079 9th Sep 2013 4:44pm
J90
France 2006 Range Rover Vogue Td6 Java Black
How can you tell if you have TPMS fitted? I have a 2006 TD6 with 18" wheels. Obviously I cant take the tyres off the wheels to see. Do TPMS valve stems look different to the naked eye from the ordinary ones?
I suppose I could let the air out of the tyres and see what happens Very Happy
Post #209272 10th Sep 2013 9:21am
i doubt if you have tpms valves on yours.....metal valves are a givaway..... ... - .- -.
Post #209273 10th Sep 2013 9:24am
J90
Thanks Stan.
Post #209274 10th Sep 2013 9:26am
