Home > Maintenance & Mods (L322) > Wiring Diagram for SC 2006 RSE wireless headphones transmit
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Hi Guys,
I need your help, I am doing an upgrade in my D3 but need the wiring diagram in detail for the FFRR rear RSE with wireless headphones from a 2006 SC.
can any of you guys help please
thanks Rob Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #207969 4th Sep 2013 3:03pm
i remember you asking this back in May and not getting any info..
there's a denso manual and a workshop manual in the wiki..there might be something in those.. ... - .- -.
Post #207972 4th Sep 2013 3:20pm
robbo770
got the manual download, it helps as it now identifies the overhead console with the required transmitter, but no part number, hopefully someone can assist or a breakers who has one can chirp up!
even a damaged console as I will be removing the transmitter for use in the D3 anyway!! Current vehicles
Gone
Freelander 06 SE
Post #208006 4th Sep 2013 5:39pm
part number you might get from the online microcat, again links are in the wiki.. ... - .- -.
Post #208014 4th Sep 2013 5:56pm
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
I might be able to help with the wiring diagrams, is it just the transmitter details you need? I have a copy for vin 239036 onwards although it is also labelled 07-09 if that is of any help, i cant believe that on 06 could be any if not much different. On the face of it the components seem the same, mostly Alpine equipment etc. Also have you see the great write up by another member,Ajay ? where he has retrofitted the RSE into a D3. I can also email a copy of that it you need it.
Regards Jon. MY2007 S/C - Stornoway / Jet
Post #208165 5th Sep 2013 8:26am
robbo770
Hi Jpickie,
I have seen the write up , as I then did another one with some picks as well from it;
the issue is I need the bits that a FFRR has to allow the wireless headphones to be used, I have a pair of these already new, and know they work with a 2006 SC setup, so what to replicate it into the D3.
how it plugs in looks like both outputs from the RSE are duplicated and sent to the transmitter, but where and how this is done is one question.
the actual unit in the roof I need and the loom, but that's another challenge to identify.
any help would be greatly appreciated and I am sure will be done by many others afterwards.
thanks Rob Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #208441 6th Sep 2013 10:00am
Jpickie
Hi Rob,
I have just uploaded the wiring diagram for the headphone unit into my gallery for you. From what i can see both the audio channels (A & B) are broadcast on the MOST network at the RSE unit and picked up on the main audio amp and from there it is hard wired upto the transmitter in the headlining. This would make sense as i have had the system apart once to find a fault and there was no wiring from the RSE unit upto the transmitter.
The part number for the rear overhead plastic console for RSE in ivory is FHB500170NUG although i can't work out if that includes the transmitter not not. I don't think it will be difficult to find a complete one at a breakers as i was looking for a DVD changer a while back and there are quite a few broken supercharged L322's out there.
I hope this helps with the puzzle a little more, Regards Jon. MY2007 S/C - Stornoway / Jet
Post #208605 6th Sep 2013 7:07pm
robbo770
ThAnks for the info, first time I have seen the proper wiring diagram for this, and looks striaght forward,
Does anyone have any Images of the connections at all both in the overhead transmitter and the loom at all.
I am way up in Aberdeen and there is no breakers for miles with any SC with RSE and was wondering if anyone knows of one and is able to do a collection service for a nominal fee.? Say £50 for the helpfull person!!Bow down Bow down
Thanks Jpikie for al your efforts Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #208669 7th Sep 2013 9:11am
robbo770
Thumbs Up BUMP Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #210480 15th Sep 2013 7:21pm
robbo770
Jpickie wrote:
Hi Rob,
Hi Jon,
just to let you know I got this working, still looking for the amp grey plug and a socket to make a good jump inline connector, but here is the thread of the finished article working.
thanks for your help again, without it never would have got it done.
http://www.disco3.co.uk/forum/topic92518.html Thumbs Up Thumbs Up Thumbs Up Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #221267 6th Nov 2013 8:38pm
