![]() | Home > Technical (L322) > TDv8 drive stutter |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
Injector cleaner is not going to help. You need to have it plugged in to determine which injector is at fault, and replace it |
^ Injector cleaner, and a QUALITY one, works every time with this fault In my experience |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Dont know how easy access to the injectors is on the TDV8 but on a previous vehicle with easy access it was possible to feel the injectors pulsing and easy to identify the faulty one because it wasnt pulsing....
BG244 Diesel Fuel System Cleaner
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 ![]() ![]() ![]() |
BG244 on order, thanks for all the help, fingers crossed.
Put the bg244 in and after 200 miles the eml came on for another 200 miles then went off.
So need to get it plugged in to see what the EML came on for? |
But the stuttering is decreasing right? |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 ![]() ![]() |
[/quote]So need to get it plugged in to see what the EML came on for?
Yes better, so maybe give it another dose? Still the original egr's, tdv8 has 2?? |
if never attended chances are minor that they r ok
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Yes, it has 2 x EGRs.
