Home > Technical (L322) > Towbar fitting
just watched that, a few oops moments in that video, though i dont know how you can get the bumper off any other way, maybe pull more gently...... or possibly a bit of furtling with a screwdriver to release the clips. There is nothing that can't be fixed with a hammer😜😜
Post #205815 26th Aug 2013 7:03pm
n1cktdv8
I'm glad you said they broke, thats how it sounded to me !
Spanners will be at the ready but am taking my time..... Is this where I put the car details and a bit about myself ?........
Post #205819 26th Aug 2013 7:07pm
Exactly!
Warm water and a good reason why when you wash your vehicle to spend some time jetting water into each crease. half the problem is the Censored that cakes in there and the other is the plastic just gets old and brittle, hence the warm water treatment. 1/2 fill a kettle and boil, then when boiled fill to max marker with cold water and give it about 30seconds to cool down just a little more and then pour over each side before removal.
To fit the towing parts you also ned to remove the rear bumper iron. This means work in the boot which isnt too bad really. I did mine from 6pm to 1am one night taking my time and no cracked lugs Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #205823 26th Aug 2013 7:28pm
n1cktdv8
I'll try 6am - 1pm....I dont function well at 1am unless beer is involved ! Is this where I put the car details and a bit about myself ?........
Post #205843 26th Aug 2013 9:23pm
Well with an ff you'll see more of it with all the sleepiness nights you'll be getting Wink :p FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #205848 26th Aug 2013 10:20pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
https://docs.google.com/file/d/0B58lCjoHzo...sp=sharing
Fitting Instructions from LRO/Topix.
Hope they are of some use.
Post #205899 27th Aug 2013 10:19am
n1cktdv8
Thanks for fitting but had a few quotes and am considering a fitter do it..
My local fitter spoke about the warm water and plastic tools to remove the bumper - which impressed me as he sounds knowledged - and he quoted £550.00 for detachable with genuine plug and play 13 pin supply and fit with warranty.
Next closest was PF Jones with £487.00 supply only for matching kit, £644.00 fitted
For the added £80 I think am just going to get it fitted....
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #205907 27th Aug 2013 11:38am
Dolphinboy
Nick, I have a second hand but 2005 "as new" armature (not been fitted as far as I can see) and removable tow bar and neck sitting in my garage.
I bought it for my 2002 by mistake and you only need the electrics (£50?) and ECU if you don't already have it (£90?)
Pics are in my gallery. Pm me with an offer.
Post #205930 27th Aug 2013 2:00pm
Danwilderspin
the links are dead in this wiki anyone able to rreupload? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #566109 2nd Sep 2020 12:58pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Yep the post is a little old.
All the manuals are on Topix if you want to download them. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #566115 2nd Sep 2020 2:08pm
Johnniehec
That’s the wrong video, that only removes the outer cover of the bumper, no good for fitting a tow bar. The only valid part is pulling the sides out. You don’t need to take the black trim off and the four screws under it, nor the screws along the underneath. Instead you need to lift the spare wheel cover, remove the locker covers either side of the boot, where all the electrics are, then the floor trims either side to get at the four bumper bolts at each side ,8 in total and remove their 16mm nuts. The whole bumper then comes off in one piece (the bit he removed and the bit he left) there’s a much better video on here somewhere, I’ll have a look for it.
Post #566148 2nd Sep 2020 9:54pm
stuart_2006
The video I followed for full bumper removal is [https://www.youtube.com/watch?v=aISGcPDdkwc]. Having a ratchet spanner for the bumper nuts is a big timesaver.
Post #566153 2nd Sep 2020 10:37pm
bigbo
You can certainly do it that way but I would argue that you are making an unwieldy item into a heavy unwieldy item.
I did my tow bar by myself so doing that would not be easy apart from the fact that once you have released the sides (preferably not by tugging them apart) the rest of the bumper cover removal is quick and easy.
It also gives you the chance to replace all the rusty clips and screws with stainless parts.
On top of that getting the bumper screws lined up through the tow bar armature and into the body work would be done blind.
The job is also made easier if you buy/borrow an air ratchet to remove and replace the bumper nyloc nuts, its a tedious job especially on the left where there is little room to swing a spanner.
Overall it was a reasonably easy job to do albeit a heavy one. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #566154 2nd Sep 2020 10:40pm
