![]() | Home > Technical (L322) > Problems with driver's seat adjustment |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
connections under the seat, might be corroded or not fully together. ... - .- -.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Mine had similar problem last year. Worked a bit but only in some directions for a couple of goes and then when I had got it to full recline it stopped all together! Had to drive to the dealer with the seat right back. Coincidentally this happened the day it was due for a service and MOT.
just0007 Member Since: 12 Sep 2010 Location: london Posts: 56 ![]() ![]() ![]() |
Hopefully someone can help, my seat is only going backwards is there anyway of manually adjusting? It is now fully back and reclined and the garage is quite far away. I'm going to look like one of the youths that drive around with the tops of their heads showing! |
