Home > Technical (L322) > l322 dropped on the o/s/f |
b20wht Member Since: 08 Apr 2013 Location: lincs Posts: 45 |
p.s Just looked out the window at the RR and its bloody sunk again on the o/s/f. Is it most likely the airbag? |
29th Jul 2013 8:44pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
probably...stick it in off road and see if it leaks. ... - .- -.
29th Jul 2013 8:57pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
As Stan says - it may be that the leak (crack or split) is just above normal ride height on the bag so rises ok to reach normal height. when it extends a bit further towards off road it opens the split and so never makes it fully up. The leak is probably enough to seep out slowly under normal conditions hence it drops eventually.
30th Jul 2013 7:19pm |
Yes you are spot on, I did this earlier on today and I can hear it out the bag. Ordered 1 today so fingers crossed should be here tomorrow and will get fitted. Should be a dam site easier to fit than the rear drive shaft I also had to fit today!! Along with road tax and a rear rose bush it has been a bad month for my RR and I'm only in the 3rd month of ownership. Fingers crossed it will be kind to me now for a few months
30th Jul 2013 8:00pm |
