Home > Maintenance & Mods (L322) > Another problem - overheating and low coolant
Stebo
2003 Range Rover Vogue 4.4 V8 Giverny Green
Might well have been. Over easter I replaced the rubber (gum) breather pipes and got the coolant sorted, it's running alot better now.
Coolant change is handy btw, but it would be worth getting a bit of pipe to put onto the radiator tap as it is directly above a bar and therefore if you just put a bucket under the tap it splashes off the bar and seems to go everywhere except the bucket.
Post #16480 12th Apr 2010 12:42pm
