Home > General > Just what you don't need at the start of a road trip
F'in dead battery.
Not used it for a week or so. It's parked in the garage without the alarm on. Opened the door this morning and the interior light didn't come on so put it on charge.
This evening, still completely dead.
Found a guy selling one but he's not in until midnight.
Tomorrow I'm on a road trip with trailer to the UK.
AAAARRRRGGGHHH.
What's mega annoying is the battery is under warranty, so I'm likely to end up with two batteries.
Also, the battery side is against the wall. Not sure I'll be able to fit it by myself. Big Cry
Post #198631 12th Jul 2013 6:56pm
Vogue
Make sure you put your bonnet into access mode makes it a hell if a lot easier! Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #198633 12th Jul 2013 7:07pm
RCusden
Wales
I know the feeling rebuilt the compressor reset the fault codes working suspension. Lasted two day now have to go on holiday in the ford Big Cry
Hope you get yours fixed in time
Roger
Post #198636 12th Jul 2013 7:12pm
Well, got the old one out. Pretty easy actually - with access mode (thanks for the tip - but I knew about it), and by standing on the wing to lift it out.
Just need this guy to phone me when he's back to pick up the new one.
No chance of me going in the other car. It's a shopping trip and my 3500kg trailer will be full on the way back. The VX220 doesn't even have a tow bar. Laughing
Post #198640 12th Jul 2013 7:39pm
sorry to hear that Kurt...hope the trip goes ok.. Wink ... - .- -.
Post #198642 12th Jul 2013 7:43pm
The battery is FIAMM by the way. It's had a tough time starting her sometimes when I had a dodgy injector, but it's still only 15 months old.
Anyway, I'm sure the trip will go ok - but thanks for the concern. Thumbs Up
Post #198643 12th Jul 2013 7:47pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
What's this bonnet access mode? I assume its something that gets the bonnet a good bit higher than normal for better access to the battery location? 4.4 TDV8 Vogue Baltic Blue MY11
Post #198666 13th Jul 2013 12:29am
^ Yes. You undo the clips on the gas struts and pull the struts off. Lift the bonnet higher and there's a lever to slide out that holds the bonnet in a vertical position. Can't see you getting the battery out any other way, though doubtless someone has.
Well, the guy with the battery said he'd be in at 1:15am, so I said I'd be there. He told me to bring cash, which I did. It seemed like some drug deal, cash changing hands in the middle of the night, but he was very nice and gave me a receipt and a 3 year warrenty.
Just put it in and starts up no problem. Road trip back on schedule. Just need to get some kip first!
Post #198669 13th Jul 2013 12:57am
Hope the trip goes well. Thumbs Up
Whereabouts in the UK are you going? Si. <This is my name.
Post #198672 13th Jul 2013 6:36am
Baron
Thanks. I hope you have a good trip and everything goes to plan. 4.4 TDV8 Vogue Baltic Blue MY11
Post #198707 13th Jul 2013 12:19pm
Budgie
Here's the Wiki thread on the access mode: http://www.fullfatrr.com/forum/topic16561.html Wink
Post #198757 13th Jul 2013 9:13pm
Baron
Thanks for the top tip. I actually tried the extended bonnet opening thing out today, only I completely removed the strut clips. Didn't realise you could just slide them down.......I know now though.
Thanks. 4.4 TDV8 Vogue Baltic Blue MY11
Post #198766 14th Jul 2013 12:32am
A tip for you guys... Take the end off from the car then tuck the shocker in under the bonnet carpet cover Thumbs Up That way, when you drop it back down, they dont scrape the wings (EASILY DONE)
Post #198780 14th Jul 2013 10:00am
Dusseldorf, Antwerp, Calais, Kent, North London, Reading, Gloucester, London, Gloucester, Birmingham, Uxbridge, Kent. Calais, Unknown so far, home.
Trip going well so far, although I have to call Craig later where he'll tell me all the expensive things that are wrong with my RR. Shocked
Laughing
Post #199023 16th Jul 2013 7:23am
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Access mode is not needed - , have replaced sofar inexcess of 5 batteries (have lost count)- its just how you swing the damm thing in Laughing
Post #199039 16th Jul 2013 9:18am
