![]() | Home > Technical (L322) > Tdv8 (07) vibration at low rpm(D engaged) and ca 2200 rpm |
Have a look around the forum for fuel system cleaners that are recommended for diesel and hopefully you can get them in Poland as well. MY 2010 5.0 SC Galway green and sand interior!!
THIS is what you need...
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Don't they need the diesel version Gaz? |
Yes sorry I googled to quickly...
andrzjb Member Since: 01 Jun 2013 Location: Poland Posts: 19 ![]() ![]() |
some update.. today weather changed and additional symptoms arrived...
one more update .. however important...just back from outside.. I decided to make some test
I checked vibration from TB one more time with harder pipe... unfortunately only sound from TB what is probably normal if we consider millage .... hmmmm now I back to beginnig |
Halk Member Since: 23 Feb 2014 Location: Greece Posts: 5 ![]() ![]() ![]() |
Hi andrzjb,
In some way.....yes ...i spent 1000 pounds for front suspension repair what had not changed anything
Thx for replying and sorry to hear that.
Ok so
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 252 ![]() ![]() ![]() |
Have same issue in my car, slight vibration that can be sensed through gas pedal when car is at 2000-2300 rpm. It did drive me nuts at the beginning, I even tried to contact you @andrzjb through other forums, posted a new topic about this on this board as well. Now I think it is most likely common, maybe all of these cars have it, I decided to live with it. 12 4.4 TDV8 Vogue
