Home > Technical (L322) > Whistling from air conditioning
nigelt28
United Kingdom 2010 Range Rover Vogue TDV8 Java Black
Hi
Just wondered if anyone has had a similar problem??
Whilst at motorway speeds, I get quite an intermittent loud whistling sound from the AC. The sound appears to be coming through the vents. I'm pretty sure it's not a half open vent or anything like that as it stops immediately when you turn off the AC.
It has only started with the recent hot weather - so when the AC is working hard.
It's a 3 year old TDV8 3.6.
Thanks
Post #198019 8th Jul 2013 2:28pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
I have that too ... assumed that it was something to do with the vents African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #198048 8th Jul 2013 5:37pm
I get that too …. Thumbs Up
Post #198049 8th Jul 2013 5:43pm
Googsy
Me too Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #198051 8th Jul 2013 5:51pm
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
and me ...
drives you up the bloody wal Big Cry Big Cry
Post #198170 9th Jul 2013 11:38am
You probably have the Roger Whittaker edition vents fitted.... Whistle Previously..
Post #198171 9th Jul 2013 11:48am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I've had whistling from center vents, usually slightly adjusting the blue/red wheel stops it.
Post #198186 9th Jul 2013 2:54pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i get the whistling some times too, not all the time just for 10-20 seconds then stops only does it when im on the motorway
matt
Post #198189 9th Jul 2013 3:26pm
