Home > Maintenance & Mods (L322) > Another water in boot thread! |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 |
Hi all,
16th Feb 2013 6:22pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
The top corners of the tailgate seal are a known problem, the seal just doesn't like being bent round the corners resulting in water ingress to the boot area below.
16th Feb 2013 8:53pm |
Thanks guys, i have some good quality sealant that i will try on the boot seals.
16th Feb 2013 9:01pm |
The water tracks down from the top corner of the tailgate seal, between the D post body panels and also behind the D post internal trim and then drips on the bits below the level of the rear fixed side window.
16th Feb 2013 9:11pm |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 |
I had a good pint of water in the spare wheel well, new tailgate seal from Dan and it's been bone dry ever since |
16th Feb 2013 10:22pm |
I have refitted the old seal, and with the boot still stripped out and talc'ed i took her to the carwash.
17th Feb 2013 5:49pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3751 |
I took out the bungs in the spare wheel well, next to the compressor. Any water getting in finds its way straight out. Plus its hidden behind a shroud so you don't get any spray coming in. OK as long as you don't go very deep wading, or if you do just put the bungs back in. |
17th Feb 2013 10:26pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
My new motor had a small amount of water in the boot well (good name for it . . . ).
6th Jul 2013 7:37pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I put a few large bags of silicone desiccant granules in my side equipment compartment, that way if there is ever a leak the bags will absorb it before it gets to the modules and I'll be able to see/feel if there is a leak before any damage is done. |
6th Jul 2013 8:22pm |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
I have rebuilt my compressor today and I found that my spare wheel was soaked with beads of condensation and was wondering if this could have been caused by the compressor getting hot as it was overworking and that was causing the condensation or does any one else know what could cause this ?
6th Jul 2013 8:57pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Had the same water issue and a new seal from Dan sorted it out |
7th Jul 2013 3:47am |
