Home > Technical (L322) > Wont start after fitting new battery
Fowey
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
It all started when my 57 Range Rover tdi 3.6 failed to start when being left for a couple of days without driving it so yesterday I took the battery to a local auto electrical firm who confirmed the battery was kaput.
After charging my brand new battery and fitting it this morning it won't start and I just get a click when I turn the key to the starter position.
With the old battery whenever I charged an re-fitted it the car started first time.
Is there any reset procedure or anything anyone else can suggest before I call the main dealer?
I guess it is possible the starter motor has failed but it seems a big coincidence
Confused
Post #196267 26th Jun 2013 5:29pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Have you tried With jump leads? Could be that Your New battery isn't strong enough. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #196269 26th Jun 2013 5:33pm
Are you sure the terminals have been tightened up enough? It sounds like a bad connection... Thumbs Up Previously..
Post #196270 26th Jun 2013 5:36pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
^ +1
They have to be super tight.
Post #196272 26th Jun 2013 5:47pm
+2 Thumbs Up
Post #196277 26th Jun 2013 6:03pm
Fowey
Hi Guys
Thank you for the advice, I will check the terminals for tightness and try and jump start from the trusty Defender in the morning.
Post #196336 26th Jun 2013 8:08pm
adigorn
It may look like your alternator makes a massive short
and battery drain
Post #196384 27th Jun 2013 6:40am
Fowey
Hi Guys
Battery terminals are super tight and makes no difference when I try to jump start it.
Looks like its a call to the main dealer Sad
One of the mechanics at my local garage said there may be a battery disconnection / reconnection sequence but I don't see anything about that in the handbook.
Crying or Very sad
Post #196795 29th Jun 2013 10:29am
GraemeC
There is a battery disconnect procedure - it's in the wiki
I would disconnect according to the procedure, check the new battery is charged with a multimeter (search for threads on here as I'm not 100% on the process) then reconnect and see what happens.
Don't forget to 'reset' the computers by turning the wheels to full lock on both sides and holding at full lock for a couple of seconds (it's in the battery disconnect wiki)
Good luck! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #196799 29th Jun 2013 10:40am
