Home > Wheels & Tyres > Mixing All Season with Winter Tyres
Flashman
I know I will probably get slated for suggesting it, but I have a pair of Pirelli Scorpion Zeros (Mud & Snow) with 6mm Tread and a pair of Pirelli Scorpion Ice and Snow tyres with 7mm tread.
I was wondering if it would be ok to run with a mix Zeros on the front and Ice and Snow on the back, all on 19 inch alloys?
I only drive a TD6 so no racing etc. Some reviews say it is ok, others push for spending a fortune on same tyres all round. My thoughts are that as long as the sides are matched there should not be too much of an issue.
Any thoughts and experiences on mixing? Tom
Current Drive
Previous Drives
Post #191144 29th May 2013 10:34am
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
It may well be safe enough to do as your suggesting but I think anything that could perhaps compromise the safety or handling of vehicle is something best avoided if at all possible...just my opinion Thumbs Up
Post #191149 29th May 2013 11:27am
Firstly, in the summer it probably wouldn't make a great deal of difference, but I still wouldn't do it.
Secondly, when it's cold and especially when you hit snow you'll have a big imbalance in grip levels, which will be dangerous.
Thirdly, just why?
Why not instead do the right thing and invest in another pair of summer and winter tyres and use them appropriately for the season?
Post #191165 29th May 2013 12:49pm
Usual advice is don't mix on an axle.
Not the same, but I have Nexens on the front and Scorpions on the back (road 20"s) and no problems here.
Guess it will depend on how extreme conditions are as to whether you would notice ANY difference at all. You could see which axle combination works best for you as well.
Given all the work the car does already, 4x4, traction control, all the *** stuff (e.g. DSC/ALB), tyres play a small part in staying on the road (contentious, awaits flame war Whistle Twisted Evil ) .
Post #191175 29th May 2013 3:35pm
Flashman
I was thinking the same, I can't see much of a difference having winters on the rear and semi winters on the front. As long as the tread depth is good on all corners it will still have grip.
There must be plenty on here driving with same tyres all round but with different tread depths which I would have thought more of an issue. Tom
Current Drive
Previous Drives
Post #191178 29th May 2013 4:03pm
Googsy
I went through 2 rear tyres on ns rear in 20k because alignment was out the others had about 7mm on each. I was going to go for 2 cheapies but managed to get 2 x Pirelli part worn tyres with 7.5 mm each on them no damage for €60 euro each fitted so same tyres fitted all round Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #191182 29th May 2013 5:00pm
Flashman
I know they can be found and I have no issues with part worns. I just have two spare ice and snow Pirelli Scorpions sitting in my garage and two naked alloys to make the set.... Tom
Current Drive
Previous Drives
Post #191183 29th May 2013 5:08pm
I've come unstuck with mixing tyres and will never do it again
Mine was on a performance car & not a FFRR, but once bitten.....
Utlimately, one set will give up grip before the others, so the car will handle in an unpredictable way - either extreme under or over steer depending on which axle has the grip.
I get that in a FFRR you are way less likely to explore the limits of grip - at least in the summer - but you never know whats lurking round that bend when its raining and you're late......
However, life is about compromises - I change tyres at 3mm, always have all 4 the same and run winter tyres Nov-Apr - but accept that others don't.
I think you know what the right answer is - any compromises are up to you.
Genuine question - I don't know what the insurance situation is regarding non-matching tyres, I guess its OK as plenty of people seem to do it.
Post #191213 29th May 2013 8:08pm
I run atrs up front and scorp zeros at the rear without issues and previously ran wranglers up front but they were low on tread. Braking and cornering under extremes was still fine for me.
The wranglers were at the end of their life which shows under braking in the wet but the current set are just great though!
If you put matching tyres on now the problem you face would be near enough the same as leaving as is really due to difference in grips between new and even slightly older tyres. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #191222 29th May 2013 8:36pm
Flashman
Some great comments, as said in an ideal world we should all be driving with 4 x identical brand new tyres with 8mm tread. But in reality this is not practical, as long as the tread depth is healthy and well balanced I am sure it will not really be noticeable. (and as long as I don't drive it like a Ferrari)
I might give it a go, with the I&S on the rear in summer and then on the front in winter. Also they are only for occasional use anyway my regulars are 20s with healthy Conti Cross Contacts all round. Tom
Current Drive
Previous Drives
Post #191283 30th May 2013 8:50am
afaik the power ratio is 60/40 with the 60% going onto the rear so i would put and keep the deeper thread tyres on the rear.. ... - .- -.
Post #191302 30th May 2013 11:37am
The consensus advice is always to put the lower grip on the front axle.
However, with radically different tyres, that's not always obvious or consistent as the weather changes....
The rationale is that most people can handle understeer better than oversteer.
Post #191363 30th May 2013 7:04pm
