Home > Technical (L322) > Towing with air susp. Inactive |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
I now have the air susp inactive message come up with no lights on the eas switch which I believe to be a compressor fault as I have heard it running longer than normal with it taking longer to raise up. It has been doing this for two days and now says on start up self levelling intact shortly followed by air susp. Inactive. I need to use it to tow my twin axle caravan will that be ok with the suspension being locked..
25th May 2013 1:45pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
Had this fault recently, don't assume compressor at fault, get it plugged in before bashing on. Mine was a height sensor, much cheaper fix. |
25th May 2013 3:36pm |
Thanks for the replies I will get it plugged in and checked and glad to know that it should do no more damage towing with it as is |
25th May 2013 5:15pm |
