Home > Wheels & Tyres > 24" split rims / losing air out of bolt / manchester
DTaylor
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Chawton White
Hi, i have 24 inch split rims on my l322. I replaced a tyre the other day thinking there was a problem with the tyre losing air, brand new tyre on. Went flat that night. Took it to garage that fitted tyre, sprayed liquid and shows air leaking from a couple of bolts, took it to refurb wheel place today, they took apart and resealed and still losing air. Im in manchester area and wondered if there was anyone that knows how to fix this problem. I dont have a spare in the mean time either, should i spray that gel into the tyre and run off that?
Post #188710 16th May 2013 4:30pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Thought I'd reply before a few of the locals take the p15 about your huge rims! I'm guessing they are split rims? The problem is a wheel of that size has huge amounts of destructive forces placed upon it during driving and as such is more probe to failure and damage. It doesn't matter how expensive they are, we don't have roads or weather like California. You could have a hairline fracture invisible to the eye that's leaking, a dangerous thing because its only going to get bigger. People weld these up and that... In my opinion is very bad practice. You could have a poor seal on your split rim due to a slight face imperfection, air will leak through 0.10 of a mm. You could have a similar problem with a bolt hole or rim lip.
Adding that green stuff is a tempory repair only and not designed for high speed or cornering or long distance. It's a get you home treatment.
A lot of people will slate your wheels, it's your car do what you want. I had my heart set on 22's but they have similar problems. I'd sell your wheels on and get a high class set of 20's or bite the bullet and replace that rim.
Post #188726 16th May 2013 6:19pm
DTaylor
wont be easy selling 3 working wheels im thinking. thought there may have been a sealer that's better than on currently or get them refurbished. guess im just going to look for 20s
Post #188731 16th May 2013 6:39pm
DTaylor
steveyd
do you know if these would fit a 2005 54plate vogue 4.4ltr
http://www.ebay.co.uk/itm/range-rover-t5-o...35c781e967
Post #188754 16th May 2013 7:58pm
Yes they will fit but the tyres are RRS size not FF size... They will fit and work but the tyres may look slim on a FF Thumbs Up
Post #188761 16th May 2013 8:09pm
DTaylor
thanks craig, do you know if these are also split rims? as they have a not on the rim and I don't fancy going through the pain again
Post #188763 16th May 2013 8:11pm
No they are not split rims Thumbs Up the small nuts are purely decorative Thumbs Up
You have a PM on its way Thumbs Up
Post #188766 16th May 2013 8:14pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Are you sure the wheel refurb place has done your 24" wheels properly. Splitting down a set of split rims and then putting them bac together is a specialist job as you have to torque up the bols tin the correct sequence or you can over stress the wheel causing the rims to warp 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #188780 16th May 2013 9:06pm
DTaylor
im guessing they didn't go into that much detail no, I would like to get that one wheel fixed and carry on. would make my life easier.
Post #188781 16th May 2013 9:12pm
