Home > Maintenance & Mods (L322) > HELP: Strong squeaking noise from rear suspension (TDV8)
verydisco
Hi all
I recently noticed a squeaking noise on my 2007 L322 (50.000 miles on the clock, FSH, very good shape under, inside and out)
I never noticed the noise with the windows up but now with the warmer days, I found out about it: if I open the windows it is very noticeable and very annoying.
It seems to come from the rear "axle".
The noises is really a kind of squeaking you would get from a rubber bushing rubbed against metal, or two pieces of Styrofoam against each other.
It is not present while just rolling on N, driving on D on smooth grounds, but really squeaking when I roll on a pothole, turn a tight cover at slow speed, drive up a sidewalk, or even simply drive on the smallest bump.
I did have the vehicle quickly checked last Saturday with all bolts and bushings checked and retighten, with no luck.
This morning I did spray all the rubbers and bolts and drove it around, again with no luck.
The indy needs to have the vehicle for a while but may have to start to work on this in steps, i.e.: change the shock absorber, hoping this is the problem. If not, then change all other bushings, again hoping this is it...
This could be expensive without even fixing it.
Any help appreciated if you have experienced this or have any clue how to fix it.
Cheers
EDIT ONE : This could be it :
GKP wrote:
Nine times out of ten the creaking from the rear suspension is caused by a failing bush in the upper wishbone (pictured and arrowed below). They're not expensive to buy - under £20 - but can be a pain to do at home if you don't have the correct insertion tool. I just remove the whole hub and press the bush in and out with a hydraulic press, but a dealer would do it in situ, so expect to be billed for about an hour's labour.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #188596 16th May 2013 8:07am
Probably your lower ball joint, easy way to check is to puncture a very small hole in the rubber and spray some WD40 in the hole with a straw attachment and voila it should shut up immediately, if not, put a blob on PU sealant over the hole to make it water tight and move on to the next... This is not a fix! It will need replacing, just an easy way to diagnose which part...
Craig Thumbs Up
Post #188601 16th May 2013 8:17am
defo a 'thursday top tip' that Craig.. Thumbs Up ... - .- -.
Post #188603 16th May 2013 8:18am
ebajema
Had it on mine as well, went away after the front suspension bushings were replaced (badly worn rubbers). MY 2010 5.0 SC Galway green and sand interior!!
Post #188604 16th May 2013 8:19am
Often comes and goes with the rain too! Water is a lube after all Thumbs Up
Post #188606 16th May 2013 8:21am
Thumbs Up Bow down Laughing
Post #188608 16th May 2013 8:21am
verydisco
Thank you to our great L322 Guru !
Checking this this morning and booking the fixing at the local Indy accordingly
Merci Craig ! Thumbs Up X10 l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #188610 16th May 2013 8:23am
verydisco
Here is how to replace the front lower ball joint lads:
http://www.rangerovers.net/forum/6-range-r...t-arm.html
Good thing I did not book the full alligment this week as planned! Whistle l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #188613 16th May 2013 8:25am
No worries J Thumbs Up
Post #188614 16th May 2013 8:25am
how to is in our wiki as well ..its the same as the RR.net one.. ... - .- -.
Post #188618 16th May 2013 8:28am
verydisco
^^^Thanks, I may have found the issue thanks to you both, see EDIT ONE on my original post Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #188619 16th May 2013 8:37am
I'll place a euro on it, it's the rear lower balljoint Whistle
Post #188621 16th May 2013 8:48am
verydisco
ok lads, thanks.
Any tips on how to find out if it is the upper or lower one before unbolting bits and ordering the parts (or should I change both while at it?)
upper one is 35 pounds from LR, lower one 30.
Considering the labbour, it might make send the change them both, each side, no? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #188626 16th May 2013 9:19am
Googsy
I would just change both Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #188634 16th May 2013 10:11am
verydisco
^^^Makes sense really.
I just talked to the indy's boss who checked it Saturday and he confirms it comes from the rear right side, not from the front at all as there is no play whatsoever in the front lower ball joints.
I will keep you all in touch. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #188635 16th May 2013 10:14am
