Home > Wheels & Tyres > TPMS Warnings |
it can be turned off if you have diagnostics which can edit the CCF file, for example the IID tool or a Faultmate. Do a search on here for TPMS and you'll see a load of similar issues. I turned mine off for similar reasons, i.e. being unreliable. |
2nd May 2013 6:25am |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
I get this and so do some other members. It's an age thing; batteries in sensors fail after 6 or 7 years, so new sensors needed 2007 TDV8 Vogue SE Java Black |
2nd May 2013 7:21am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Whilst my TPMS has no issues at the moment, I purchased a set of new sensors from eBay for about £30
2nd May 2013 7:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35430 |
..and, the corrosion on the valve stems... ... - .- -. Y. O. L. O. . |
2nd May 2013 7:58am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Thanks all! I'll get it fixed when I have it in for servicing, but my excellent indie mechanic is NOT close by, so I don't just 'drop in.'
3rd May 2013 7:10pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
ID3 tags? ID2 tool?
14th May 2013 6:56am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I also get this occasionally. Maybe once every 30 minutes.
14th May 2013 7:47am |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
It is common, but it is a fault!
14th May 2013 2:51pm |
Thanks.
14th May 2013 3:18pm |
I've been running my SC for three years the TMPS warning only comes on when one of the tires is too low on pressure. Haven't had any false alerts, so it sounds like you have battery issues. MY 2010 5.0 SC Galway green and sand interior!!
14th May 2013 3:40pm |
