Home > Maintenance & Mods (L322) > CEC conversion sorted.
Googsy
Weather has been crap . Managed to strip everything down and fit new wing brackets and topbar. I have soldered all the new Pdc and fog light looms. The bumper is fully assembled. But I haven't got a clue how to repin the. Lights Big Cry i cant proceed with fitting grill and bumper unitil lights are sorted have to work this out by tomorrow as need the car for work on Monday. I have to repin lights and have been looking and trying to figure out what or how to repin Any help greatly appreciated. Wish I lived in the UK as would have got Craig to do it in the first place. It really is a lot more complicated than it looks and best left to the professionals Big Cry Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #187777 11th May 2013 5:05pm
Re: CEC conversion first day stuck....
Thumbs Up Give me a bell tomorrow Conor and ill see if i can help you... Thumbs Up
Post #187828 11th May 2013 11:46pm
Googsy
Bow down Bow down Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #187829 11th May 2013 11:48pm
Am hillclimbing at Prescott tomorrow so if you dont get an answer straight away, keep trying Thumbs Up
Post #187831 11th May 2013 11:51pm
Googsy
Cheers I know where I will be and it won't be hill climbing Laughing Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #187832 12th May 2013 12:02am
Googsy
Pm sent Craig Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #187981 12th May 2013 11:11pm
flow11234
United States 2003 Range Rover Vogue SE 4.4 V8 Giverny Green
i have tried it yet but i had asked the same question and got this answer
Hi there! Saw your request for a wiring schematic for converting a early L322 to a 2010 model. Sorry for the weird layout in this message, I can't seem to alter it to look normal. On the 2010 Range Rover, there is a 16 pin connector, with 16 individual wires. You don't need all of them. I have a pre 2006 Vogue (rectangular connector plug on the back of the headlight, and two 2 pin connectors for indicator and parklights. I live in EU, so have no sidelights on my car. On the 2010 headlight, following pins are for following functions: Pin1, earth lead for marker function, goes to mass on side light plug of 02 model. Pin 2 Earth for the indicator, goes to earth on the indicator plug of the 2 pin connector. Pin 3, indicator, goes to positive lead of the indicator. 4 = positive lead for the marker lights, together with pin 16! (else your markerlights will flicker). Pin 5,6,7,8 are not used. Pin 9 = Xenon ECU Earth, connect to pin 7 on 02 plug. Pin 10, connect to pin 9 on 02 plug. Pin 11, connect to pin 6 on 02 plug. Pin 12: co0nnect to pin 8 on 02 plug. 13,14 and 15 are not used. 16 connect to positive lead on 02 marker light 2 pin connector. Adaptions to make it error free: Connect a load resistor parallel from the positive lead of the indicator to earth. (do the same for the rear). Connect a small load resistor parallel on the marker light plus lead, to earth. Fogs: Nothing special up front, just change the connectors to H11. For the rear, do the same trick with the indicator. The fog light wire: If you don't need it in the US, simply cut it (else the leds will keep flashing). If you do need it, put a relay between it and power it through a zener diode, which has a switching voltage of 4 volts. (Zener diode is a small thing which lets through the current if the voltage is higher than a threshold value).
let me know how this work out
Post #187982 12th May 2013 11:20pm
Googsy
Almost there just a bit of tidying to do.Thanks to Craig Stryke Harvey and Flashman for all the help
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #188097 13th May 2013 6:25pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Looking good
Post #188102 13th May 2013 6:48pm
Nice! Thumbs Up Si. <This is my name.
Post #188103 13th May 2013 6:49pm
Very nice Conor , looking good Thumbs Up Thumbs Up Bow down
Post #188106 13th May 2013 6:52pm
Flashman
Looks awesome Conor. I just need to paint my new bumper and take delivery of the new armature and I can then do the same as you when I get a couple of sunny days and no work meetings. They really look great with the 2010 front end. Tom
Current Drive
Previous Drives
Post #188112 13th May 2013 7:25pm
Thumbs Up glad I could help Conor... Now where's my f Censored g bars? Whistle Rolling with laughter
Post #188151 13th May 2013 9:44pm
Harvey123
United Kingdom 2006 Range Rover Autobiography Td6 Java Black
Conor i dont want to jinx it but mate the car looks lovely.. Well done! Range Rover Autobiography Black Conversion
Post #188152 13th May 2013 9:48pm
Googsy
I'm polishing them as I speak Craig Thumbs Up thanks all. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #188153 13th May 2013 9:55pm
