Home > Wheels & Tyres > TPMS Warnings
RR2008HSE
TPMS Warnings
My 2008 V8 (NAS) has been giving off TPMS warnings to 'check tyre pressure." I've checked ALL the tyres including pulling out the spare and checking it (a pain). The warning is intermitent, but getting worse.
How to fix?
Can this be turned off until I have it in for its regular service in about 6-8 weeks?
FYI: The car has stock 20" rims.
Help much appreciated! Thanks in advance.
Post #186100 2nd May 2013 1:06am
mzplcg
it can be turned off if you have diagnostics which can edit the CCF file, for example the IID tool or a Faultmate. Do a search on here for TPMS and you'll see a load of similar issues. I turned mine off for similar reasons, i.e. being unreliable.
Post #186105 2nd May 2013 6:25am
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I get this and so do some other members. It's an age thing; batteries in sensors fail after 6 or 7 years, so new sensors needed 2007 TDV8 Vogue SE Java Black
Post #186110 2nd May 2013 7:21am
GraemeC
Whilst my TPMS has no issues at the moment, I purchased a set of new sensors from eBay for about £30
When the seller finally gets round to sending me some nuts they will be fitted along with some new tyres
This is purely a precaution before the batteries in my exisiting sensors start to go.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #186120 2nd May 2013 7:56am
..and, the corrosion on the valve stems... ... - .- -.
Post #186121 2nd May 2013 7:58am
RR2008HSE
Thanks all! I'll get it fixed when I have it in for servicing, but my excellent indie mechanic is NOT close by, so I don't just 'drop in.'
I was wondering if it could be turned off without the ID2 tool?
Post #186442 3rd May 2013 7:10pm
SteveMFr
Site Sponsor
ID3 tags? ID2 tool? Laughing
You need a diagnostic system capable of ccf-editing. The dealer can't (as this option is not avail on the OEM IDS diagnostic system). AFAIK the only options are either a BBS Faultmate or IIDTool as Dom (mzplcg) mentioned above, or possibly an Autologic system as well - tho I am not sure on this.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #188171 14th May 2013 6:56am
I also get this occasionally. Maybe once every 30 minutes.
In the few days I've owned my S/C, this hasn't changed and I've assumed it's similar to a system check whereas the warning comes on and then goes off after a minute or so.
I may be wrong on this, so please correct me and I'll claim it under warranty. Si. <This is my name.
Post #188187 14th May 2013 7:47am
sleepezy
It is common, but it is a fault!
Mine does it in warm weather - fine for 99% of the year but a pain on the odd really hot day!
Under normal conditions the warning should not come on at all, even on start up.
Post #188253 14th May 2013 2:51pm
Thanks. Thumbs Up
OK, I'll claim that under the warranty. Si. <This is my name.
Post #188256 14th May 2013 3:18pm
ebajema
I've been running my SC for three years the TMPS warning only comes on when one of the tires is too low on pressure. Haven't had any false alerts, so it sounds like you have battery issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #188259 14th May 2013 3:40pm
