Home > Maintenance & Mods (L322) > Cargo Net - Standard on Vogue SE?
MikeG
Netherlands 2007 Range Rover Vogue TDV8 Santorini Black
Mutley, it's probably a 5 minute job... Thumbs Up It doesn't fit in the grooves of the load space cover, you actually take out two plastic covers (one on each side) near the side windows in the cargo area. These just lift up when pushing/pulling with your fingers. Then you install a bracket and new piece of plastic where the dogguard net holder clicks into... These two new brackets and plastic pieces (don't know any other name for it... Laughing ) require two screws for each side. When these two pieces are fitted you basically click in the cargonet holder in 2 seconds.
Please check if in the ceiling of the cargo area there are already the brackets where the cargonet fits into when you pull it up. I believe it's standard fitted but mine came with additional brackets which I didn't have to use.
By the way you can still use the load space cover when you leave the dog at home, it fits underneath the dogguard net.
For your information, I'm not the most technical person but I did it in 5 minutes so this is a job everyone should be able to do in less then 5 minutes... Very Happy
Cost will depend on where you buy it but since I couldn't find a complete used set I ordered a new one which costed me about 350 Euro... Still cheaper then a damaged leather back seat, funeral for the dog after damaging my back seat and a divorce from the SWMBO as a natural responds... Whistle
I believe taking everything in consideration it was a good long term investment and personally think I looks better in an FFRR then the metal dogguards do... Had one of those in a Discovery before but like this one better. Mike.
2007 Range Rover Vogue TDV8, Black, Sand Leather Seats & Sand / Black Interior.
IID Tool from GAP Diagnostics.
Post #185918 1st May 2013 8:18am
Mutley
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi Mike,
Thanks for that I will go & search for the best price, thanks for replying so quickly, as for the dog she is on the back seats in a soft dog cage, but now she waits to shake her Censored off when she is in the car, I am sure she is doing it on purpose Rolling with laughter Rolling with laughter Mr. Green Laughing Mutt
FFRR Black TDV8 Vogue MY08
Post #185948 1st May 2013 11:42am
MikeG
I'm sure she is... They are all the same... Big Cry Mike.
Post #185952 1st May 2013 11:49am
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
The luggage net can be fitted but you need to buy the trim bits & the brackets to hold it in place. I have just done it on mine, the cost of the 2 trims & brackets were about £90 from Dan, the net was bought from ebay & you will need 4 bolts & 2 screw to fit the brackets/trims
Post #185961 1st May 2013 12:16pm
