Home > Maintenance & Mods (L322) > Finally sorted a few "jobs" on my 2003 TD6 !
RS2000CUSTOM
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Santorini Black
Well here is my first thread on FFRR
I have owned my TD6 since Sept 2012 and have covered 7000 miles since owning it
Well all the engine bay jobs needing sorting so last week I made a start
I work for myself as a freelance MOT tester and have a small unit in Wednesbury where I do service / repairs and quite a lot of diagnostic work
Here is what I got upto last week !!!!! Whistle
Replace the following :
Intercooler
Intercooler hoses
Glow plugs
Rocker cover breather
Water pump
Thermostat
All fan/aux belts
Oil and Filter
Diesel Filter
Correct spec anti-freeze
EGR blank and K+N Air filter (yes I know the purists dont like em and evidence out there that they not much cop - but I like em - lol)
Remove and check :
All 6 injectors as I have diagnosed 1 is "bleeding off or leaking"
____________________________________________________________
So here is what I managed to get done inbetween 5 MOT's and a service today !!
Cylinder 5 Injector certainly looks "leaky" !
Post #185585 29th Apr 2013 6:44pm
RS2000CUSTOM
Plenty of room to poke around now Surprised
The "caked-up" inlet manifold is all clean (horrible job !) and ready to go back on once I get my injectors back from being tested/checked/overhaul if needed
Post #185587 29th Apr 2013 6:44pm
RS2000CUSTOM
All injectors came out with only the slightest "tap" to loosen em Very Happy
Well had all 6 injectors tested and 1 was "leaking back" as though it was an open tap and another one was leaking back slightly but enough to warrant overhauling
Inj 5 tested OK and when I checked the dribble rail seal it was clear the seal was "flattened" in one area enough to cause the dampness seen on a previous pic
I collect the 2 overhauled injectors in morning but have fitted the 4 serviceable ones
Water pump and stat fitted and 2 x new belts (number shown so if you need a belt these will be the part numbers you will need
The intercooler is fitted in the plastic housing and thats pretty much all I can now do until tomorrow
I could have rebuilt the front end but whilst I have all the front off I can get to the engine area real easy so couldnt be RS'ed to refit it yet
Post #185588 29th Apr 2013 6:45pm
RS2000CUSTOM
(This was 21:30 Friday night !!!!!)
Now finished and runs a treat
So am loaded up ready for a trip upto to Blyton Airfield in the morning for a trackday in an MG TF135
Post #185589 29th Apr 2013 6:46pm
Aspin83
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
wow some amazing work looks well towing the trailer too, do the td6 have the swirl flap system as per the bmw 530 diesel engine ??
Post #185592 29th Apr 2013 7:02pm
RS2000CUSTOM
Thankfully no swirl flaps were on my TD6 and I am led to believe no TD6 Range Rover has the pesky little blighters fitted - lol
Post #185598 29th Apr 2013 7:10pm
Aspin83
that's good I had to do a full engine rebuild on a 530d as a swirl flap decided to let go in the cylinder lol looks well though Cool
Post #185611 29th Apr 2013 7:27pm
RS2000CUSTOM
swirl flaps is a common fail on the 3.0 D Sad
Post #185623 29th Apr 2013 8:07pm
Aspin83
yeah and a expensive one too ha ha hence why I went for a s/c RR, was unsure weather they had the swirl flaps [/img]
Post #185629 29th Apr 2013 8:20pm
Flaps were only fitted to the auto boxed bmw's and nothing else from what I know Wink
R2000 would it be easier to strip the front end out to get at the injection pump or would it be easy to from the top? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185666 29th Apr 2013 10:03pm
RS2000CUSTOM
Not sure at all but even with the amount I removed from the engine/bay the HP pump was still well hidden away
How has a faulty HP pump been diagnosed ?
Post #185670 29th Apr 2013 10:15pm
Fuel rail isn't getting upto pressure and then spits out an error code and it won't fire without some easy start or such to get the engine upto tick over quickly as I'm guessing the pressure is too low Sad also the glow plug relay is throwing a fault code so need to check that as well but it was showing 28,000(approx) kpa on diag for fuel rail pressure when last fires up so not 100%.
Primary pump seems fine as flows plenty of fuel and is only a few months old. In tank is about the same as well.
Replaced injectors 5-6 as they were showing more fuel flow and balancing than the others and that's now resolved a little.
Ill pm you a link to the thread so as not to hijack yours though if that's ok?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185672 29th Apr 2013 10:25pm
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Whats a swirl flap please?
Why is the need for a jubilee clip on the air filter?
Mines seem to be a tight fit.
Awsome thread, thank you Thumbs Up Made in Scotland frae 'Girders'
Post #185678 30th Apr 2013 1:03am
swirl flaps,
http://www.swirlflaps.co.uk/what-are-swirl-flaps.html ... - .- -.
Post #185684 30th Apr 2013 5:53am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
K&N's come with jubilee type clip Bofa Mine was a blue one! Smile
Post #185699 30th Apr 2013 7:14am
