Home > Camping, Caravanning and Holidays > Gas Regulator - Responsible person required.
Gaslow way to go.... Whistle
Post #221492 7th Nov 2013 5:00pm
This is my very safe Gaslow set up (mine is exactly same in Dethleffs garage) you fill up like an LPG car in a filler on side of Van:
Post #221494 7th Nov 2013 5:07pm
gaz
Gaslow stuff is great as you can fill up when needed, however if your set up is the same as the one in the pic, it still goes through a truma regulator before going into the van, which is where the problem lies. There is nothing that can't be fixed with a hammer😜😜
Post #221507 7th Nov 2013 6:33pm
mzplcg
Trev18 wrote:
Hi... mzplcg
Have you fitted it instead of the new unit or as a extra precautionary measure before it
I still have my originals so would not cost a bean....
Trev
I removed the Truma junk. Fitted a length of flexi hose up to the metal pipe and put a standard bottle mounted regulator on the other end. Seriously, it took 10 minutes, cost me a fiver and I've never looked back.
Plus of course, the Truma bulkead thing is a compromise on pressures. It's set at 30 millibars. With the red (propane) or blue (butane) bottle mounted regulators you actually get the correct pressure for that gas, not a mid-point compromise. Gas oven now cooks a roast in about 75% of the time it used to take. (yes, we have roast beef and yorkie puds in the caravan)
HTH
Dom
Post #221510 7th Nov 2013 6:49pm
No high pressure hoses in the gas locker either! Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #221512 7th Nov 2013 6:51pm
