Home > General > 1 week anniversary - broke down already :(
Robbieowens
United Kingdom 2005 Range Rover Vogue Td6 Santorini Black
Went to start the car this morning, opens fine most dash lights come on, no warning error, touch screen doesn't come or radio, strange noise coming from behind the dash. Put key in, turn - nothing - doesn't even attempt to start! Could be the battery but I don't have a tester, time to call the RAC
Post #184607 25th Apr 2013 8:22am
sounds like the battery ...if it starts after the jump make sure you set the steering parameters.. ... - .- -.
Post #184608 25th Apr 2013 8:25am
Robbieowens
Thanks Stan, not the start I wanted to owning a FFRR but never mind, hopefully just the battery and Rac will sort it. How do you set the steering parameters?
Post #184621 25th Apr 2013 8:35am
after the range has started turn the steering wheel fully left and then fully right , this avoids getting error messages on the dash..info is in the wiki under 'battery disconnection' ... - .- -.
Post #184623 25th Apr 2013 8:39am
Robbieowens
Thanks Stan, still waiting for RAC. Is this a common fault I.e. what appears to be a good battery dying overnight? Nothing was left on in the car.
Post #184675 25th Apr 2013 11:35am
the fullfat is very heavy on the electronics and any battery around 3 years old might need changing..some have had the same battery for longer without any problems but generally its 3 'ish years..
if you do need a replacement ,maybe when the winter comes upon us ,then get a bosch/varta 020 110 amphrs/ 920cca from somewhere like ECP with a discount code... ... - .- -.
Post #184676 25th Apr 2013 11:47am
Robbieowens
Disaster averted Wink battery and alternator both fine, car started fine off jump! "Problem" was rear map light left on, solution ban the kids from the car!
Post #184684 25th Apr 2013 12:43pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
you'll find anything left on overnight in a FF will drain the battery lol. These things will happen Laughing you only really need to worry if the battery is not holding the charge or if the alternator once running is generating anything less than about 14v. But if both of those are fine then make sure your FSR is working ok.. Other than that most likely to be the kids leaving a light on Laughing Laughing Laughing Bushy
2003 RR Vogue Monté Carlo Blue
Post #184689 25th Apr 2013 1:04pm
ebajema
Or take the bulbs out Whistle MY 2010 5.0 SC Galway green and sand interior!!
Post #184690 25th Apr 2013 1:04pm
Or fit LED ones like a lot seem to do and they will drain less power and stick a 110ah battery in the front and a spare in the boot Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #184694 25th Apr 2013 1:11pm
RR2008HSE
My Dad had tons of problems with his (non-Land Rover) mini-van. All the electronics were very good at keeping the engine sounding and starting well as the battery got worse and worst. It did cause just about every electric gizmo to malfunction though. Finally, the electronics reached their limit and the battery 'suddenly failed'.
The electronics do a great job, but they do make things more confusing.
I'm glad you got it sorted so easily. Keep the kids out the the FFRR, that's what the roof racks are for! Mr. Green
Post #184805 25th Apr 2013 11:25pm
mjdronfield
Rolling with laughter
Very good - I don't have kids so don't need a roof rack! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #184811 26th Apr 2013 6:11am
