Home > eBay & Bargain Spots > Maybe Useful For Someone...
pami
United Kingdom 2008 Range Rover Vogue SE TDV8 Bournville
These look useful for the 2010+ rear light upgrades..
http://www.ebay.co.uk/itm/Range-Rover-Rear...257d1f0ca3
Unless its just me who is useless at electrics/mechanics! Whistle
Post #184369 23rd Apr 2013 10:11pm
no, you do need these units to sort out the fog and flickering you get when fitting leds to the range..i have seen these for less mind.. ... - .- -.
Post #184411 24th Apr 2013 8:52am
Flashman
Module might not be necessary
Check the light on your car first, on some models the fog and indicator work ok, there might be some slight flickering at start up, but if you have the IID tool you can turn off the hot and cold monitoring that causes it.
I have a 54 plate touchscreen Vogue with the original front end and did not need any module to get them to work, I am not sure about the front lights but will try them soon. Tom
Current Drive
Previous Drives
Post #184412 24th Apr 2013 8:54am
