Home > Wheels & Tyres > Disintegrating Tyre Valve - 2007 Supercharged
pld118
Today for the first time, I went to the nearest tyre machine.
Started on rear offside tyre and noticed the valve looked old.. put the tyre inflation connector on the valve and it partially disintegrated.. resulting in more air escaping than being put in.
Post #184334 23rd Apr 2013 9:15pm
mzplcg
It's a common issue with the TPMS valves. These are made of aluminum and don't get replaced when tyres are done. They suffer with salt and electrolytic corrosion as you might expect and the only cure is to replace them.
Count yourself lucky. Most of us manage to snap off the whole thing which allows all the air to escape and leaves you reaching for a jack & wheel brace.
Post #184354 23rd Apr 2013 9:41pm
Best advice would be to ditch the TPMS sensors and valves, then get an IIDTool and turn the damn things off! Got - 2017 SDV8 Autobiography in Loire Blue
Post #184356 23rd Apr 2013 9:44pm
pld118
'Dont get replaced'... Too tight to replace them?
Post #184359 23rd Apr 2013 9:47pm
No, because if they're not broke, they don't fix them!
You should seriously think about removing them altogether, I don't recall anybody having anything good to say about them! Got - 2017 SDV8 Autobiography in Loire Blue
Post #184362 23rd Apr 2013 9:51pm
mzplcg
No, I mean they don't get replaced when tyres are changed because of long life design. Sometimes the valve core is changed but the TPMS sensors have batteries and solid valve stems which theoretically are good for 7 years. Otherwise you'd be looking at a new TPMS sensor with each new tyre, not a small amount of money.
Like Alan said, replace them with standard rubber items, turn off the TPMS and your life will be much more peaceful.
Post #184363 23rd Apr 2013 9:51pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Thats what I've just done........and I've got 4 brand new TPMS sensors sitting in my garage ready to be fitted but decided against it.... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #184564 24th Apr 2013 9:25pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
At full price I expect cost v hassle isn't worth it...
However I bought a brand new set of 4 off eBay at £31 (had to chase seller to supply nuts).
All work perfectly. Notice that these ones appear to be plastic rather than the horrendous alloy.
Mine did fail at petrol station, catastrophic loss of air Big Cry Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #184570 24th Apr 2013 9:37pm
