Home > Maintenance & Mods (L322) > Found Out How To Fit The Supercharged Side Vents
How to Install Range Rover Side Vents
Tools Needed: 10mm Socket or wrench
Time Required : 30~45 min. for pair
Step 1
Open the hood and locate the screw on the top of the vent.
Step 2
Reach the bottom of the lower panel (the panel underneath of the vent) and pull hard towards you. The panel (made of plastic) is flexible and fastened by clips.
Step 3
Do not take off completely. It will make you difficult to put it back.
Step 4
Remove the top screws using 10mm socket or wrench.
Step 5 & 6
Locate the bottom screw and remove it using 10mm socket or wrench.
Step 7
Remove the vent.
Step 8
Removed.
Step 9
Compare the new Supercharged (A) and original (B) vent.
Step 10
Remove the back panel from the Supercharged vents. They would not fit without removal.
Step 11
Back panel is removed.
Step 12
Install the new Supercharged vent (Installation is a reversal of removal).
Step 13
Push back the lower panel securely.
As Gordon Ramsay would say DONE !!!!!!!!!!!!!!
Just have to order the new chrome ones now ====================================
Post #930 26th Sep 2008 6:12pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Perfect Just need some standard SC vents now
Post #932 26th Sep 2008 9:12pm
