Home > For Sale & Wanted > Venture Cam
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Venture Cam
i have for sale a complete boxed venture cam. In the box is the bracket with suction cup, the holder and a cam which i have checked today in my FFRR to see that it charges and displays a picture correctly. It also switches angles and the lights go on and off from both the cam and the touch screen.
i would describe it as in excellent condition. I know these are quite rare complete and in good order, so i am asking for £100, which seems under priced as there are two listed on ebay in America, one at £850 and the other at £1000... Rolling with laughter Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #181540 6th Apr 2013 1:29pm
GreenBlood
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Pm sent If you don't get stuck then you are not trying hard enough.
2012 FFRR TDV8 Westminister
Gone: Def90 2.8i, Def110 2.8i
Gone: RRC 2-Door and 4-Door, 2007 FFRR TDV8 Vogue
Gone: Aussie Spec D1 V8, D2 V8
Post #181544 6th Apr 2013 3:05pm
shalz
Kenya 2011 Range Rover Vogue TDV8 Santorini Black
second dibs if greenblood doesn't want it... MY11 Vogue 4.4 TDV8 - "African Queen"
Post #181546 6th Apr 2013 3:18pm
stu
sorry now sold!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #181565 6th Apr 2013 6:42pm
Stornoway SA
Does a Venture cam work on MY2012 Vogue???
Post #222108 11th Nov 2013 6:42am
stu
Not 100% sure, but does it not have all the surround cams fitted? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #222116 11th Nov 2013 8:33am
Stornoway SA
Yes but the rear camera is hopeless - my D4 was ten times better; thought the venture cam would be useful to add to rear bumper when attaching the caravan.
Post #222132 11th Nov 2013 10:30am
stu
I just reverse the car close to the caravan and then drive it on to the tow hitch using the motor mover. Best money I ever spent. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #222140 11th Nov 2013 11:25am
its just not a matter of buying a venture cam, you need the charging port fitted and the ccf updated.. ... - .- -.
Post #222147 11th Nov 2013 11:49am
