Home > Off Topic - Other Cars > M Class OR x5??? |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Both good cars,
21st Apr 2013 4:14pm |
DaWalley Member Since: 24 Jan 2013 Location: Cheshire Posts: 42 |
Cheers for the info!! RR Vogue TDV8 08 |
21st Apr 2013 4:17pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Well, I tried both extensively about 18 months ago. Personally, I'd take the BMW over the ML, but you need to try them both; neither are anything much like the FF to drive. I found the X5 to be quite car-like, the ML was less so, but neither felt as big (or luxurious) as an FF or indeed the D3.
21st Apr 2013 4:19pm |
Oh yes. I forgot the bloody run flats. Nightmare. Graham
21st Apr 2013 4:20pm |
I couldn't stand the things, ripped them off after one change cost the same as a small car. Bushy
21st Apr 2013 4:22pm |
Yet again, thanks! I have heard a lot about the run flats being annoying / costly, but most other points seem to be favouring the X5 really.
21st Apr 2013 4:23pm |
Yes, I had them on a 330D - noisy, hard ride, poor grip esp in the wet, wore out quickly, bloody expensive, no choice, and unrepairable. A sidewall tear meant I was stranded and the "run flat" feature didn't work. Had to be recovered (luckily I had a spare car at the time) and a week to get a new tyre.
21st Apr 2013 4:25pm |
if I couldn't have the FF the X5 would be my choice, but I'd swap the wheels immediately. Just like any other BMW if they get looked after, their a brilliant car. Bushy
21st Apr 2013 4:27pm |
Dont forget the X5 suffers badly with worn rear bushes that cause the wheels to toe-in at the rear and shred the inside of the tyres
21st Apr 2013 4:41pm |
Thanks. I'll make sure to check on it for these too. RR Vogue TDV8 08 |
21st Apr 2013 4:45pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7802 |
X5 every time. But then I'm more of a "BMW Man".
21st Apr 2013 4:46pm |
Has she driven the RR?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
21st Apr 2013 5:18pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Get a Honda cr-v.... If you are not going FFRR then you might as well go sensible and bullet proof reliability. Previously..
21st Apr 2013 6:38pm |
campaj1 Member Since: 22 Oct 2012 Location: Cheshire Posts: 729 |
go for a current generation X5 if you can stretch to it: the handling belies its size! |
21st Apr 2013 10:39pm |
