Home > Technical (L322) > Brembos....
Page 1 of 3 123>
Brembos....
Im about to strip down my brakes as they are squealing a bit, not binding though.
I was just wondering if anyone had changed the pads on the front brembos. Never done anything more than a single pot caliper before and am unsuire of how to retract the pistons. Im surr it will be self evident when i take them apart but dont want to get into it if its tricky.
Think the brakes just need a bit of grease on the back.... There is nothing that can't be fixed with a hammer😜😜
Post #169555 2nd Feb 2013 3:44pm
Googsy
My pads need changing too so I watch this thread with interest . I think there is a how to from Bodsy on Disco3 in wiki. Not the same as RR but similar. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #169563 2nd Feb 2013 4:22pm
Googsy
My pads need changing too so I watch this thread with interest . I think there is a how to from Bodsy on Disco3 in wiki. Notbtge samel as RR but similar. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #169566 2nd Feb 2013 4:35pm
Easiest of all the pads to change gents... Remove the resevoir cap first! Then Ideally you need a long punch to knock out the pins, clean and copper grease the spring and pins, pull out one brake pad only! push back the 2 pistons on that side, copper grease the rear of the pad and slide it in... Repeat with the 2nd pad, slide the first pin back in and tap home with a hammer and punch, refit the spring and slide in the second pin... Easy peesey Thumbs Up
Craig...
Post #169567 2nd Feb 2013 4:35pm
Cheers craig, how do you push the pistons in? Pair of grips on pad edge and caliper and squeeze? There is nothing that can't be fixed with a hammer😜😜
Post #169569 2nd Feb 2013 4:47pm
I have a special tool but a screwdriver through the holes that hold the pins will do or like you say a pair of grips on the old pad... Just dont scratch the caliper!
Post #169574 2nd Feb 2013 5:10pm
Coolio.
Think im going to have a bash tomorrow, along with replastering the bathroom and swapping wheels entertaining the kids and going out for lunch. There is nothing that can't be fixed with a hammer😜😜
Post #169577 2nd Feb 2013 5:20pm
Googsy
Thanks Craig aint forgotten your tubes!
Northern if doin could you take a few pics please as I have never changed pads before and its a job once started has to be completed Thumbs Up
C. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #169581 2nd Feb 2013 5:31pm
I think the NSF doesn't have a brake warning sensor so do that side first... If you are to re-use your sensor then remove it carefully! 40% of the time they snap so if that will leave you in trouble then order one before you attempt the job Thumbs Up
Post #169585 2nd Feb 2013 5:56pm
C.
Post #169586 2nd Feb 2013 5:56pm
I think there is a bit of meat left on the pads, so just a copper slip job. There is nothing that can't be fixed with a hammer😜😜
Post #169641 2nd Feb 2013 9:05pm
Done the fronts, easy job actually, craig was right brembos are a piece of p155. Knock out the two pins with a drift, top one first, take care of the spring, squeeze the pad towards the caliper with some grips and reomve the pads.
Simples no spanners needed.
Still squealing though, looks like it is the rears. Which have just been done at the dealers...... There is nothing that can't be fixed with a hammer😜😜
Post #169749 3rd Feb 2013 3:35pm
Bet there's no copper in the rears...
Thumbs Up Thumbs Up Thumbs Up
Post #169769 3rd Feb 2013 5:18pm
probably right, its easier to do them my self than take them back to the stealer. They put new pads in when they did the calliper and i bet they didn't put any paste in there.
I have started using Pagids ceramic paste rather than the copper grease on the last few sets of pads i have done. Seems to work and it comes in a small tube for a couple of squids. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #169787 3rd Feb 2013 6:51pm
Googsy
right I think i will try this. Have see some on eBay brembo, ebc, and mintex are these okay as replacements? I'm going to try and reuse sensor although will buy one just in case . Oh and what's a drift? I was going to buy a c clamp to push piston back in. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #169812 3rd Feb 2013 9:06pm
Page 1 of 3 123>
